converting d16a6 to obd 1 checklist help
Old May 22, 2005 | 09:04 PM
BxCrx91's Avatar
Default converting d16a6 to obd 1 checklist help
ok just let me know if i'm missing anything or if i am wrong about something. Thanks.
i am thinking about getting the rywire obd 0 - obd 1 full conversion harness with distributor adapter harness as well.
so far i got a obd 1 dizzy from a 94 del sol non vtec
4 wire o2 from a 99 si
and a p72 from a obd 1 gsr
now will the distributor i got from the del sol bolt on to the d16a6 head?
and does anyone know if the the 4 wire o2 gets spliced into the rywire harness?
and is the p72 from the gsr ok or do i need a sohc p28?
Old May 22, 2005 | 10:14 PM
Rywire's Avatar
Default Re: converting d16a6 to obd 1 checklist help (BxCrx91)
We will add a factory 02 sensor plug to the subharness with factory honda pins.
I would use the sohc non vtec ecu(obd1).
Old May 22, 2005 | 10:30 PM
NikoZai's Avatar
fyi, The P72 cannot be run without being chipped. agree with above. sohc non vtec boyeee
CX/DX/LX OBD-1 dizzy's ALL fit the A6 head with no mods. (not the z6 dizzy tho, oddball)
Rywire (we) build our O2 harnesses for Honda/Denso Primary 4-wire O2 Plugs.
And we sell them if thats not what you got
Primary = wires in 02 plug poke your finger .. Male pins.
Secondary = pins are flush with white plastic cover.. female pins.
Rywire does need to know this to make your harness plug and play. Otherwise you'll have 2 ends of the same plug and you'll have to splice them together or send it back to Rywire. By default we attach the 4-wire plug for the Primary 02. If you're using a Bosch o2 that has no plug, just wires hangin, we'll just send you wire w/o plug since you'll have to direct wire it anyway.
On a side note:
(That guy that posted above is Ryan from Rywire and i'm Peter from Rywire and Ryan has a final to take in 2 days so Ryan should be studying not posting on honda-tech right now LOL but he's addicted. I'll get him help, don't worry.) baaahahaha
Old May 23, 2005 | 12:20 AM
whiteknightef's Avatar
Default Re: converting d16a6 to obd 1 checklist help (NikoZai)
hey im doing a conversion in my car too, is it possible to get a better deal than $190 from you gents. im broke, and my car got stolen, then recovered and they stole my vtec controller. my frend gave me a p28. so i need to by your harness. do i need the ecu plug harness(110) and the sub harness(55) for the p28? i know i need the dizzy plugs. im running a d16z6.
Old May 23, 2005 | 05:20 PM
BxCrx91's Avatar
cool thanks for the fast replies guys. yeah my p72 is chipped with hondata s200 so i'll be running that ecu. I will let you guys know when i'm ready to order. First, i need to get my car some minor bodywork and fresh paint. Next is the obd 1 stuff.
antballs420
Sep 28, 2008 01:09 PM
freddysEF
May 16, 2007 07:32 AM
puertoroc7976
Oct 10, 2006 05:19 PM
Screaming
Jan 29, 2006 06:53 PM
ironcheftony
Dec 19, 2003 04:57 AM
