ok to use stock honda lug nuts on volk te-37? (i already searched)
so my question is: can you use stock honda lugs on volk te-37 (or other volks?). i know that you "shouldn't" since the volks take tapered nuts and the stock hondas are rounded, but does it really matter?
TIA!
TIA!
https://honda-tech.com/zerothread?id=1188922
"What lug nuts do I need?
12x1.5 - Stock wheels use an acorn/ball/radius style, aftermarket wheels use a tapered/conical/tuner style. No, it is not safe to mix and match (stock wheel with tuner lugs or vice versa), the contact between the lugnut and the wheel will be insufficient, putting undue stress on them and potentially causing failure."
you got served! by a n00b...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikochu »</TD></TR><TR><TD CLASS="quote">you got served! by a n00b...
SHOCK!!!! hahahahaha..and ya answer is "NO"
</TD></TR></TABLE>SHOCK!!!! hahahahaha..and ya answer is "NO"
Petah
Apr 15, 2003 05:10 AM
