DOHC zc ecu code 9!!!!1
Old May 22, 2005 | 07:37 PM
stw88crx's Avatar
Default DOHC zc ecu code 9!!!!1
my zc is throwing code 9. it bogs down some and lost its power ban at 4 and 6k rpms. can anyone help. i have already put a brand new dist. on it.
Old May 23, 2005 | 03:37 PM
stw88crx's Avatar
Default Re: DOHC zc ecu code 9!!!!1 (stw88crx)
bump
Old May 23, 2005 | 03:54 PM
Redline130's Avatar
After you changed the distributor, did you reset the ecu?
Old May 23, 2005 | 06:53 PM
seekerONE's Avatar
this may sound weird but you need to check the timing belt to make sure that the cam timing is right...i had this problem before
Old May 24, 2005 | 07:59 AM
stw88crx's Avatar
i have reset the ecu many times i think i need the cam gears timed.
Old May 24, 2005 | 09:38 AM
Kryogen's Avatar
to set the Cam gears, with the belt off, get 2 5mm punches and theres a little hole ontop of the 1st cam cap get the hole in the cap to line up with the hole in the cam and stick the punches in. This is assuming the bottom.end is at TDC, put belt back on, she will drive like new.
90civic-ZC
Nov 21, 2011 12:07 PM
ijustchillin
Apr 9, 2007 02:26 PM
drjondurst
Oct 2, 2005 09:28 AM
crxzcracer
11
Apr 12, 2004 02:27 PM
seeweed
Feb 12, 2002 09:05 PM
