Suspension & Brakes Theory, alignment, spring rates....
ITR vs. GSR suspension geometry: really that different?
Old May 22, 2005 | 07:23 PM
JunIntegra's Avatar
Default ITR vs. GSR suspension geometry: really that different?
Well i was thinking recently that the ITR is known for its best handling FWD capabilities and the normal tegs are never even brought up. From what ive seen, the only difference APPEARS to be the increase in spring rate and better shocks. so is this really all the magic to teh type-r or is there completely different geometry to the suspension?
Old May 22, 2005 | 07:43 PM
azian21485's Avatar
Default Re: ITR vs. GSR suspension geometry: really that different? (JunIntegra)
better chassis
Old May 22, 2005 | 07:44 PM
azian21485's Avatar
Default Re: ITR vs. GSR suspension geometry: really that different? (azian21485)
oh and lsd
Old May 22, 2005 | 08:13 PM
Tad's Avatar
Tad
on difference i see is that the chassis
is stiffer(thought I doubt it's enough to be even noticeable)
springs/shocks,
and the real big difference, the big *** rear swaybar w/built in tiebar in the back..
Old May 22, 2005 | 09:33 PM
PIC Performance's Avatar
ITR's are also lighter, afaik.
Old May 22, 2005 | 11:54 PM
slammed_93_hatch's Avatar
every suspension part has the SAME exact geometry as normal tegs. (not all the same parts but suspension mounting points are all the same.)
Old May 23, 2005 | 05:36 AM
00R101's Avatar
Default Re: ITR vs. GSR suspension geometry: really that different? (slammed_93_hatch)
Big, big difference is in the bushing materials. ITR has stiffer bushings than GSR et al.
Also rear suspension is quite different (although geometry is the same) Different LCAs etc.
Also ITR ride height is lower from factory.
The question is - can you make a regular Teg handle as well as or better than a stock ITR? The answer - yes but with compromises - either is will ride rougher or have less suspension travel or be much more expensive.
Overall it's hard to beat those Honda engineers. They gave up some NVH for better handling and did it at a reasonable price.
Old May 23, 2005 | 09:12 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: ITR vs. GSR suspension geometry: really that different? (00R101)
Same:
rear UCAs & bushings
rear compensator arms & bushings
front UCAs & bushings
front swaybar
front LCAs & bushings
front knuckles & balljoints
Different:
rear LCAs (same geometry)
rear trailing arms (same geometry but probably different bushing)
rear swaybar
rear swaybar bushings
rear swaybar end link bushings
front & rear shocks
front & rear springs
front & rear upper shock mount bushings
front swaybar bushings
front swaybar endlink bushings
front LCA compliance bushings (same geometry)
Old May 23, 2005 | 09:52 AM
adseguy's Avatar
Default Re: ITR vs. GSR suspension geometry: really that different? (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Same:
front swaybar
Different:
rear swaybar
front & rear shocks
PUT IT TO THE MAN!
bigslimdog
Dec 31, 2011 08:57 PM
HomeDepotMade
Suspension & Brakes
Jul 23, 2005 12:31 PM
serious
Dec 11, 2002 08:33 AM
tweekerz
May 6, 2002 05:59 AM
