B18B1, Fuel
Old May 22, 2005 | 07:03 PM
wileycoyote0022's Avatar
Default B18B1, Fuel
I have a 1995 Integra LS, with the B18B1. I have rebuilt the Head completely. All Crower: Stage 3 Cams, stainless vavles, titanium valve springs, Ported and Polished, STR Fuel Rail, Vemon 440cc Injectors. AEM Fuel Regulator, Injen Intake, Tusudo Exhaust. I have my fuel set a 40lbs at idel and max's out at 50lbs at full throttle. My engine idels low like it is to rich ( 250 - 600 RPM) and then at high RPM it cuts out like it doesnt have enought full. Anyone have any sudjestions? Thanks
Old May 23, 2005 | 09:44 PM
blackeg's Avatar
Default Re: B18B1, Fuel (wileycoyote0022)
how are you controlling the 440's?
they are way to big to run properly on a stock ecu.
could also double check your ignition timing at the distributor
Old May 24, 2005 | 11:23 PM
mtber's Avatar
You need to have your vehicle tuned :-)
Check out http://phearable.net
I am located in the Tampa, Florida area.
Old May 25, 2005 | 02:46 AM
Takumi Fujiwara's Avatar
Default Re: B18B1, Fuel (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">You need to have your vehicle tuned :-)
I am located in the Tampa, Florida area.</TD></TR></TABLE>
00gs-r
Sep 26, 2008 10:35 AM
jdmls88
Sep 11, 2006 12:17 PM
xtremecoupe
Dec 9, 2005 06:06 PM
rewerbcrx
Oct 19, 2005 08:31 AM
TypeRuz
Nov 19, 2003 11:40 AM
