Suspension & Brakes Theory, alignment, spring rates....
kyb agx adjustables...question
Old May 22, 2005 | 05:35 PM
reconstructdead's Avatar
Default kyb agx adjustables...question
i have a 92 civic si with agx 4-ways and eibach pro kit springs...ive been running all the shocks on setting 3, ive tested them out on 4 a couple times through some hard corners. does it matter if they are set on 4 all the time? i keep them on 3 now. also, is this true: while adjusting the shock if you push down too hard on the dial, can it blow the shock? i've heard this, but didnt know if it was true, so ive always adjusted them very very slowly and carefully. can too much adjusting damage them?
thanks for any help
Old May 25, 2005 | 04:57 AM
Default Re: kyb agx adjustables...question (reconstructdead)
can anybody help me out here?
Old May 25, 2005 | 06:20 AM
mike-y's Avatar
leaving them on 4 should be just fine. I have those shocks on an integra and usually just leave them at 1 or 2 most of the time. Sounds like you are adjusting them correctly. I never heard of blowing them by pushing down too hard on the adjustment screw, but then again, I never felt the need to mash it down with the screw driver. I just push down, turn, release.
Old May 25, 2005 | 08:39 AM
Default Re: kyb agx adjustables...question (mike-y)
it may be possible to have some type of spasm just as you are adjusting the shock....thus, erratically mashing down on the dial.
Old May 25, 2005 | 07:44 PM
eMpAtHy's Avatar
the stiffer they are, the harder they have to work. obviously leaving them at a lower setting will allow them to last longer. you dont want to overdampen the car. that is also bad.
vtecmaster85
May 17, 2015 12:46 AM
power11
Suspension & Brakes
Jul 14, 2007 03:42 PM
nyrican23
Suspension & Brakes
Jul 4, 2007 03:34 PM
BCrawford
May 6, 2005 05:56 AM
joeseph
Dec 5, 2002 11:13 AM
