SI map sensor on HF
Old May 22, 2005 | 03:40 PM
ryan89crx's Avatar
Default SI map sensor on HF
ok i want to replace the whole map sensor/vaccum line routing in my HF with an SI one. the HF has 4 vaccum lines coming off it going to the motor, but the SI only has 2. Since i have an SI motor, i dont have the EGR valve, which is where one of the extra lines went to. also on the HF there was another line going into the manifold but on the SI there isnt. So i have 2 extra lines hanging. Does anyone have any pics of how the SI lines are routed so i can figure this out without having vaccum issues?
Old May 22, 2005 | 03:46 PM
Gumbey75's Avatar
Default Re: SI map sensor on HF (ryan89crx)
when i did the hf to sohc zc( like the si) all i did was run the hf map sensor and all the rest i threw away never had a problem since. just caped off the lines on the Intake manifold. and there was no plug for the EGR. and the fast idle on the back will not have a plug as well.
Old May 22, 2005 | 03:53 PM
ryan89crx's Avatar
Default Re: SI map sensor on HF (Gumbey75)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gumbey75 &raquo;</TD></TR><TR><TD CLASS="quote">when i did the hf to sohc zc( like the si) all i did was run the hf map sensor and all the rest i threw away never had a problem since. just caped off the lines on the Intake manifold. and there was no plug for the EGR. and the fast idle on the back will not have a plug as well. </TD></TR></TABLE>i understand this. ive been running my sohc zc for about 6 months now. im putting my a6 in now and dont like the extra vaccum lines from the map sensor just hanging there. i have them plugged right now, but i want them gone
Old May 22, 2005 | 04:22 PM
Origin's Avatar
you can have them gone. just unscrew the map sensor from the rest of the unit and you wont have all those vacuum lines. just the map sensor, and i believe when i did this i only had one line, not two.
detuned
Jun 26, 2008 01:58 PM
drewboy
13
May 14, 2005 10:11 AM
lewsscroos_
30
Apr 14, 2005 09:18 AM
coot_er
Feb 11, 2005 11:38 AM
crx1856
Aug 18, 2003 10:55 AM
