Bore question
ok im either gonna get oversized ctr or p30 pistons.they are .25 overbore arent they? i asked inline four what i need to bore the block to and they said .10 over..
is this correct?
is this correct?
You can have your machine shop bore to the specified ring gap, if you are running all motor and no nitrous, .009" is good, Enough room for heat expansion. And you can have them measure each piston too.
yes 0.25mm is approx. 0.01 inch (i may have the incorrect number of zeros). honda uses metric measurements and most machine shops use standard measurements.
MatHadder
Oct 1, 2006 05:59 PM
Chief Wenceslaw
Apr 14, 2006 07:07 PM
