m/t 24.5x8x13 slicks? on stock axles
what do you think about m/t 24.5x8x13 slicks on crx stock axles?
i have been using 20x8x13's and got a best of 12.6@110, but usually get consistant 13.0-2 launching at 4,500rpm and get mad wheel spin.
I would go w/ some 22's if I were you but if you must, your axle life will depend on your driving style. I ran 24.5's on OE axles launching @ 6500+ and they held up fine. Preloading is key to saving axles and other drivetrain parts.
Phil
Phil
yeah I want to go with 22 or 23 mandh but got the m/t 24.5 for 40 bux used so i figured I'll use them up.
how can you preload,, if I let off the clutch a little it causes the car to mover forward at the staging line
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexsracing »</TD></TR><TR><TD CLASS="quote">yeah I want to go with 22 or 23 mandh but got the m/t 24.5 for 40 bux used so i figured I'll use them up.
how can you preload,, if I let off the clutch a little it causes the car to mover forward at the staging line</TD></TR></TABLE>
I would sell the 24.5's and make a profit on them then, get the 22's or 23's. You must use the e-brake (like I do) or a staging brake to hold the car form moving. I think the 24.5's will bog you hard off of the line.
Phil
Phil
turboman
Feb 20, 2006 11:40 PM
376R
Apr 18, 2005 09:30 PM
vtecmike1
Apr 1, 2004 10:19 AM
