gsr idle prob
running on jdm gsr on an EK, my idling wud drop 2 normal then go up 2 about 1500rpm, then go back down to normal idling after about 5secs,
this would happen everytime i shift 2 neutral to slow down then stop
thanx
thanx
my buddy had a problem with it in his civic SI.... he bruoght it in and all it was was some idle meter thing that had to be adjusted.... real cheap to fix....... and yea downshift to slow down.... save those brakes
or I believe even having air in your coolant system can make the idle surge like what your saying.
Easy to find out, just bleed the air out of your rad. 10 min way to start finding out what it isn't, so you can narrow it down to see what it IS.
well it could be a vaccum leak, like your tb gaskets or intake manifold gasket, listen to a hissing sound areond your intake manifold, or your isc is bad, thats the device that keeps yuour idle intact, when these things go bad, the idle goes up and down constantly.
i think my iac is alright, i cleaned so many times too, i dont see any disconnected hoses. for wat i can see neways.
also my idle speed is around 900rpm. i readjusted it down, but it always goes up there,
o yeah, i
ment when im on a stop i put it on neutral,
o yeah, i
wedgenix
May 27, 2005 07:54 PM
