5th Gen V6 Knocking
Old May 22, 2005 | 10:23 AM
aZnAcCoRd02's Avatar
Default 5th Gen V6 Knocking
Anyone ever had the valves adjusted on there 5th Gen V6??? If so is it something I can do or should i just take it to someone???
Old May 22, 2005 | 01:22 PM
xbn83's Avatar
Default Re: 5th Gen V6 Knocking (aZnAcCoRd02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aZnAcCoRd02 &raquo;</TD></TR><TR><TD CLASS="quote">Anyone ever had the valves adjusted on there 5th Gen V6??? If so is it something I can do or should i just take it to someone???</TD></TR></TABLE>
I did not perform valve clearance on 5th gen V6 yet, but however I did it on 5th gen 4cyl before. If you never do it before, then I suggest do not attempt to try. You have to get use to the feeler gauge, put the engine at TDC, etc..., basically you have to know what are you doing period. Tight the valves can't not be too tight, too loose, blah blah blah. It is not a hard job but also can be one at the same time. On V6 I could imagine there will be more work than 4cyl. The valve clearance job will cost you from $50-$100 depend on where you go. Good luck!
Old May 22, 2005 | 01:25 PM
Accord95Lxxx's Avatar
5th Gen V6 valves are not adjustable, they are just noisy at high milage. I had an 88 Legend coupe with the same engine, and my valves got clacky when the motor was cold. there are some additives youcan put in the oil, or use a synthetic blend oil that helps, and lastly ive heard of people replacing valves and springs but that is costly
Old May 22, 2005 | 01:35 PM
fw190bvi's Avatar
Default Re: (Accord95Lxxx)
i had my 4cyls adjusted cause they ticked like hell....they still do, but only when its cold out, and its not as bad
Old May 22, 2005 | 01:47 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord95Lxxx &raquo;</TD></TR><TR><TD CLASS="quote">5th Gen V6 valves are not adjustable, they are just noisy at high milage. I had an 88 Legend coupe with the same engine, and my valves got clacky when the motor was cold. there are some additives youcan put in the oil, or use a synthetic blend oil that helps, and lastly ive heard of people replacing valves and springs but that is costly</TD></TR></TABLE>
Are you sure they are not ajustable??? I don't believe that. Tell me if when you drop the cams in, the clearance is out of spec, what could you do?
Old May 22, 2005 | 02:46 PM
Chiovnidca's Avatar
Default Re: (xbn83)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure they are not ajustable??? I don't believe that. </TD></TR></TABLE>
They use hydraulic tappets that auto adjust the clearance.
Old May 22, 2005 | 06:57 PM
xbn83's Avatar
Default Re: (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
They use hydraulic tappets that auto adjust the clearance.</TD></TR></TABLE>
I didn't know that. The way the other dude said like it is fixed, can't be adjust at all. Thanks!
CB7Ninja
Feb 29, 2012 02:33 PM
reeltime80
Jan 18, 2005 12:31 PM
shadowz
Jun 14, 2004 12:04 PM
Fly1865
Sep 21, 2002 02:21 PM
AccordDriver92
Jul 16, 2002 02:59 PM
