koni yellow's from delsol 97 fit 90 EF hatch?
Rear will fit as-is, fronts require the lower wishbone mount from the later car and the spring perches and location on the shock is different so you'd be better to use a coil-over sleeve style perch for setting height. Lenghts are close enough and valving is fine.
5dots
Nov 1, 2012 06:10 PM
91civiccross
Sep 30, 2008 12:09 AM
