Honda S2000 Honda S2000
Can't get my car to stop pinging!!!
Old May 22, 2005 | 12:36 AM
KooK's Avatar
Mustang Sally
Default Can't get my car to stop pinging!!!
I have a 20002 S2000 thats bone stock minus the K&N and removed aircover (uhhh woot?). I'm currently using 93 Octain at whatever alt. Iowa is and whenever I get close to 7500rpm I start to ping like nobodies buisness. I regularly use Sea Foam at oil changes and compression is still 240 across the board (Cold engine, dry test). Can anybody suggest what might be causing this?
Thanks!
Old May 22, 2005 | 06:19 AM
neo1z's Avatar
Default Re: Can't get my car to stop pinging!!! (KooK)
Well I dont think you should use Sea Foam THAT much, and I beleive you are supposed to do a compression test on a warmed up motor - but those dont really explain your pinging. Put your air cover back on, your hurting yourself more than helping yourself there. But once again, this doesnt explain your pinging. Can you post a sound cliip of it?
Old May 22, 2005 | 06:55 AM
SuzukaBlueAP2's Avatar
Default Re: Can't get my car to stop pinging!!! (neo1z)
How many miles on the engine?
Old May 22, 2005 | 11:03 AM
KooK's Avatar
Mustang Sally
Default Re: Can't get my car to stop pinging!!! (ScreaminTeg)
46k miles, I'll get a clip next time I go out.
Old May 22, 2005 | 11:29 AM
Nishant's Avatar
tried resetting ecu?
Old May 22, 2005 | 11:48 AM
JDMjdawg's Avatar
Default Re: Can't get my car to stop pinging!!! (Nishant)
Do you have a time machine as well as your 20002 S2000? Thats awesome, does it hover too? haha
Seriously though, I cant think of anything. Maybe you need a valve job?
Old May 22, 2005 | 01:29 PM
nsxnext's Avatar
Check your oil. I'm sure it's that.
Old May 22, 2005 | 05:49 PM
Arsenal's Avatar
Default Re: (nsxnext)
haha, come on here with six posts and tell a guy to check his oil because his engine is pinging!
What is happening to Honda-Tech, mods,
There should a quiz which one has to pass before they can become able to post.
Old May 22, 2005 | 11:00 PM
KooK's Avatar
Mustang Sally
I'll reset the ECU when I can get to it tomorrow...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxnext &raquo;</TD></TR><TR><TD CLASS="quote">Check your oil. I'm sure it's that.</TD></TR></TABLE>
Ehhh buddy, first of all, that makes no sense, second, I check it everytime I get gas.
Old May 23, 2005 | 06:39 AM
Lil Corb's Avatar
maybe heatsoak from no air box cover causing excessive heat into engine through filter??? But that doesn't explain why just at 7500rpm?
idk just a guess
maddcrx
Honda S2000
14
Apr 27, 2021 11:13 AM
RED_90TEG
Honda S2000
35
Feb 28, 2013 01:50 PM
11Past9
Honda S2000
12
Mar 6, 2010 12:47 AM
Mashka
Honda S2000
Jun 4, 2007 09:51 PM
Griff
Jul 5, 2006 06:47 AM
