i think im a tard!! plz help
when making a new post, click the picture of the picture of a mountain. It will insert "[IMG]" tags. Put the web address of the picture you want in between the tags. They should all end with eithor a .jpg or a .gif ending. Good luck.
You will need a website to upload and host your pictures you will not be able to upload them from your computer unless you use a website. I suggest http://www.imagestation.com or http://www.we-todd-did-racing.com or http://www.photobucket.com etc, they are free and easy to use. After that you need to right click on the pic and go to properties then highlight the address and cut it. After that go to the reply or post option on the top right corner on a thread, there will be a button under the field that you make your comments in, it is the image button, click it ----> [IMG][/IMG] that is what it will look like then you paste the address in between the two.
Also searching on the topic would help you get your answer too
