Clutch pedal sticking then releasing a few seconds later please help !
Old May 21, 2005 | 07:33 PM
InJ3cted's Avatar
Default Clutch pedal sticking then releasing a few seconds later please help !
heres my problem, I have 1od action clutch and pp b16 and when I would shift at higher rpms the clutch pedal would stick , so I thought since the clutch cable has never been changed I thought it could be stretched maybe? Well I changed the clutch cable with one of those autozone ones and now the pedal will stick then release a few seconds later at any rpm Has anyone ever experienced this? Could it be a shitty clutch cable , does the cable have to be tied down to certain spots ? I've tried adjusting the cable with the nut but I don't think that has anything to do with it stick or does it?
Thanks in advance
Denny
Old May 21, 2005 | 08:30 PM
CRseXy's Avatar
Default Re: Clutch pedal sticking then releasing a few seconds later please help ! (InJ3cted)
Are the RPMS falling like they should? or what? check the lever on the transmission where the cable ataches, What I would do is have someone sit in the car, and push the clutch and ****. and watch the cable for binding or weird sounds.
Old May 21, 2005 | 09:25 PM
InJ3cted's Avatar
Default Re: Clutch pedal sticking then releasing a few seconds later please help ! (pogiTSI)
rpms are falling like they should and the cable doesnt bind or anything almost feels like my pp took a **** or something
Old May 22, 2005 | 07:36 AM
InJ3cted's Avatar
bump
Old May 22, 2005 | 10:21 AM
InJ3cted's Avatar
someone?
Old May 23, 2005 | 11:49 AM
CRseXy's Avatar
ITs quite possible the PP took a ****, BUT if your PP did take a ****, you would be grinding gears like woha, and either the RPMS wont fall like they should, how does your clutch feal? Is it Really soft? what clutch is it? how many miles are on it?
Old May 24, 2005 | 02:16 PM
InJ3cted's Avatar
its an Action clutch 1od pretty much an oem replacement , Clutch pedal feels normal but i've noticed that it is a little softer from when I first installed it. There is about 500 miles on the clutch. I'm thinking its the clutch cable or just a soft pp maybe if thats possible?
I called alex at action and he said he wasnt sure but he was going to take care of me.
Radim
Feb 19, 2010 11:15 AM
ninjaturtle1023
Jul 10, 2004 03:29 AM
GreenMachineRex
May 4, 2004 06:22 AM
