Will GSR TB work with LS engine/IM??
Already searched, can't find an answer.
It's a 99 LS swap, converted to OBD0, and I'm wondering if you can use a GSR TB on the LS. Also, what are the sizes of GSR vs. LS. I think GSR is 62mm stock. He wants to use GSR cuz he thinks it's bigger than LS. Thanks for all input.
-Austin
*EDIT* Let's here it for my 600th post y0!!!11
-Austin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-CeReaL#4 »</TD></TR><TR><TD CLASS="quote">90-93 is 58
94^ is 60 I believe. non-vattack
However, dont gsr tb's have some sensor on them obd2. might run into problems there.</TD></TR></TABLE>
i wonder if a obd0 gsr TB would work...anybody else care to take a crack?
I have a 94-95 JDM LS swap in my 99 Integra and I'm using a 97 GSR throttle body with no problems... You do have to change the throttle rotor, to one from an LS or B16, so the throttle cable will bolt up right...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4U2NV »</TD></TR><TR><TD CLASS="quote">I have a 94-95 JDM LS swap in my 99 Integra and I'm using a 97 GSR throttle body with no problems... You do have to change the throttle rotor, to one from an LS or B16, so the throttle cable will bolt up right...
awesome
that's the response i was looking for, thanks a lot
</TD></TR></TABLE>awesome
