Crx with all 4 gsr disc brakes, what suspension to use?
Right now i have ion gsr shocks and springs and its sitting like a truck
Im confused on which shocks and springs i will need. If anyone has any experience with gsr disc brakes on crx's, info will be appreciated. thanks
. Im confused on which shocks and springs i will need. If anyone has any experience with gsr disc brakes on crx's, info will be appreciated. thanks
i got also DC (94-97) integra disc brake Non-ABS
and using omnipower coil overs and had DA tein SS coil overs before and it still handled like a champ
no difference
using any of the suspenison that the disc brakes came from would cause that "lifted" look though
no difference
So im looking to get either DA or Crx coilovers? Krazie you made the switch from tein coilovers to omnipowers, i thought it would be switched around. Any recommondations on the best coilover on the market right now around 1000? This will be on a weekend roadrace warrior. Great info guys thanks.
This is what its going into... new project ... also lookin for sir headlights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ooairewreckoo »</TD></TR><TR><TD CLASS="quote">i have all 4 dc 94 gsr discs. Will that make a difference?</TD></TR></TABLE>
No, use CRX springs/shocks and use the CRX LCAs and you're set.
I do not have the crx lcas, the car had 5 lug suspension, but it got stolen and the previous owner installed gsr's for replacement. What model coilovers do i need if the lca's are gsr's?
You will need:
CRX front LCAs
CRX front shock forks (to prevent the lifted look)
CRX shocks front & rear (I suggest Koni Sport)
CRX springs (I suggest Ground Control)
You can use any 90+ integra, 88-95 civic/crx, or del sol:
Rear LCAs
Rear Trailing arms
Rear UCAs
Rear Compensator arms
I'm not sure if you can use integra knuckles & front UCAs...
CRX front LCAs
Rear LCAs
Rear Trailing arms
Rear UCAs
dohdoh420
11
Jan 12, 2006 11:16 PM
Emshhh
Jul 15, 2004 08:35 AM
