gsr oil and water pump in ls vtec
Old May 21, 2005 | 05:07 PM
civicswap's Avatar
Default gsr oil and water pump in ls vtec
I know that I need vtec oil and water pump for ls vtec, but can I use a gsr pump with a b16 head or do the pumps and head need to match?
Old May 21, 2005 | 05:30 PM
DOHCsideracing's Avatar
Default Re: gsr oil and water pump in ls vtec (civicswap)
You can use any oil pump from a B-series VTEC.
The 96+ oil pumps (both Honda and Acura) are the same as the ITR (but I don't think they are any better that the OBDI stuff), the only difference (as far as I know) between the the OBDI & OBDII pumps are that the lower timing belt cover on the newer pump has to be "upgraded" too, as the newer style has cut outs for the crank fluctuation sensor, and the old cover won't fit quite right.
The OBDII old pump is like $35 cheaper, but the newer timing cover cost about that, so it is pretty much a wash... I converted mine to the OBDII pump and cover, in case the pump is actually better...
<U>OBDI oil pump (#1, $126)</U>
http://www.hondaautomotivepart...EC%29
<U>OBDII oil pump (#2, $90)</U>
http://www.hondaautomotivepart...82%29
<U>OBDII Lower timing cover (#1, $36)</U>
Hope all this rambling helps...
Adrian
Old May 21, 2005 | 06:22 PM
civicswap's Avatar
Default Re: gsr oil and water pump in ls vtec (DOHCsideracing)
thanks
Old May 21, 2005 | 06:24 PM
No prob... hope it helps
stevenDAtegra
Dec 15, 2008 07:53 AM
hydroflip
Aug 6, 2007 02:07 PM
AMLS4dr200whp
Nov 14, 2006 10:07 AM
Hondasaurs
Feb 25, 2003 04:20 PM
VWkila
Jan 29, 2003 02:09 PM
