installing tachometer but doesnt work
Old May 21, 2005 | 03:47 PM
dungsta's Avatar
Default installing tachometer but doesnt work
so today i wired everything to what was sed..
red - to radio wire.. 12v
white- illumination
green - RPM input
black - to whatever is metal..
tell me if tahts correct?
i couldnt get it to light up or to work .. please help me someone .. 4 wires were cut off since my car is a 4 cylinder
Whats wrong with this setup?!
Old May 21, 2005 | 04:16 PM
CivicFreak's Avatar
Default Re: installing tachometer but doesnt work (dungsta)
here you go
http://www.autometer.com/downl...J.pdf
Old May 21, 2005 | 04:25 PM
fasthatchb18c1's Avatar
you wight wire would go to the 12v source and the red need to go to your ignition wire
Old May 21, 2005 | 05:20 PM
dungsta's Avatar
Default Re: installing tachometer but doesnt work (fasthatchb18c1)
red needs to go to ignition wire?
i been searching up so much that it says it need to go 12v
does white go to the one in the gauge cluster?
Old May 21, 2005 | 05:32 PM
Your ignition wire is a 12v switch, and yeah white could go into gauge cluster, connecting to one of the wires for a bulb.
read this https://honda-tech.com/zerothread?id=949918
Old May 21, 2005 | 05:53 PM
BlueIntegraBoy's Avatar
Red wire splice to black/yellow wire
White wire splice to red/black wire
Green wire splice to blue wire
Black is ground
Old May 21, 2005 | 09:40 PM
dungsta's Avatar
Default Re: installing tachometer but doesnt work (BlueIntegraBoy)
my white wire went to the blue with grey dots in the gauge cluster..
Old May 21, 2005 | 09:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta &raquo;</TD></TR><TR><TD CLASS="quote">my white wire went to the blue with grey dots in the gauge cluster..</TD></TR></TABLE>
That's your tach signal wire
Old May 21, 2005 | 10:55 PM
dungsta's Avatar
okay i finally fixed it and it works.. how do i adjust it? do i hold the red button then move the dial up?
Old May 22, 2005 | 12:08 AM
CivicFreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta &raquo;</TD></TR><TR><TD CLASS="quote">okay i finally fixed it and it works.. how do i adjust it? do i hold the red button then move the dial up? </TD></TR></TABLE>
Turn you key on but don't start, move the red button to the RPM you desire. Turn off the car and start your car and test it out.
Old May 22, 2005 | 12:10 PM
dungsta's Avatar
Default Re: installing tachometer but doesnt work (CivicFreak)
yeh i did that.. is it suppose to restart to a new number every time?...cus that is happening
Old May 22, 2005 | 01:38 PM
dungsta's Avatar
how come the rpm from the autometer arent correct when im driving? please help
thanks
Old May 22, 2005 | 02:12 PM
Racermech's Avatar
the stock tach is usually off, espically in high RPM. the autometer should be a lot closer to what the engine is revving.
Old May 22, 2005 | 04:32 PM
dungsta's Avatar
Default Re: installing tachometer but doesnt work (Racermech)
its at 6 rpm from teh autometer.. is there a way i can fix it?
Old May 22, 2005 | 04:59 PM
kyle92integ's Avatar
you should have only cut two wires on the back the brown and orange if its anything like mine maybe thats it?
Old May 22, 2005 | 05:28 PM
dungsta's Avatar
Default Re: (kyle92integ)
yeh those hve been cut .. i bought it used..
Old May 22, 2005 | 05:32 PM
dungsta's Avatar
Default Re: (dungsta)
the autometer idles at 6000 can i change it some how ? this is really bothering me
Old May 22, 2005 | 08:16 PM
dungsta's Avatar
need help
jnemci
Jan 11, 2010 06:16 PM
Vtakkk
Mar 3, 2006 03:35 PM
jdl3000
Jul 31, 2004 03:50 PM
