would my dc2 coilovers fit a 1st gen crx?
Old May 21, 2005 | 03:28 PM
jdmjeff's Avatar
Default would my dc2 coilovers fit a 1st gen crx?
im gettin a 1st gen crx and i was wondering if my coilovers off my 94 teg would fit it? also if not would the 2nd gen coilovers fit it also? thanks!
Old May 21, 2005 | 03:29 PM
jdmjeff's Avatar
Default Re: would my dc2 coilovers fit a 1st gen crx? (jdmjeff)
Oh and also where is a great site to get aftermarket parts for a 1st gen crx.... they are pretty rare as it is
Old May 21, 2005 | 04:42 PM
Grand's Avatar
im pretty sure the coilovers wont fit
Old May 21, 2005 | 05:01 PM
Abram AH5's Avatar
no but you can make them work probably
Compare them there prolly to tall and maybe too skinny
redpepperracing.com go there
Old May 21, 2005 | 05:12 PM
Jaker's Avatar
1st gen CRX doesn't have coil springs in the front. It has torsion bars. There's not enough room between the strut and the wheel/tire for a coil spring.
Old May 21, 2005 | 07:41 PM
jdmjeff's Avatar
Default Re: would my dc2 coilovers fit a 1st gen crx? (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">1st gen CRX doesn't have coil springs in the front. It has torsion bars. There's not enough room between the strut and the wheel/tire for a coil spring.</TD></TR></TABLE>
wait so how would i lower the car then? im confused???
Old May 21, 2005 | 08:02 PM
Jaker's Avatar
There's a height adjustment nut under the car. Its attached to the tube that houses the torsion bar. It'll only be good enough for about a 1" (maybe a bit more) drop. There's a couple other ways to drop the front end.
Re-index the torsion bar by one notch (alot of work), relocated the mounting point of the LCA to a lower position, etc...
Old May 21, 2005 | 08:47 PM
bryman10's Avatar
Grasshopper,
You will be enlightened with answers to all your inquiries here:
http://www.redpepperracing.com
good luck!
bryman
Old May 29, 2005 | 05:55 PM
jdmGSR.fo0!'s Avatar
Default Re: would my dc2 coilovers fit a 1st gen crx? (bryman10)
wow ... i used to go to redpepper waaaay back when i had my 1st gen rex... that place is awesome for info and tech articles for the old skoolers.
RD6
Mar 10, 2015 06:34 PM
CW-ITR
Jul 14, 2008 05:08 PM
RedB20DA
13
Sep 24, 2006 06:00 PM
darockstar
Apr 2, 2006 07:52 PM
