LED's in blinkers now solid and buzz from flasher.
Old May 21, 2005 | 03:12 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default LED's in blinkers now solid and buzz from flasher.
i put LED's in the rear, front, gauge cluster, and sidemarker lights and now the blinkers are solid and a very nasty buzz comes from the flasher.
can i just get a electronic flasher. or what can i do cheaply to fix this.
EDIT: it does the buzzing and solid on each side and hazerds.
Old May 22, 2005 | 01:22 AM
NastyHabitzCRX's Avatar
Default Re: LED's in blinkers now solid and buzz from flasher. (DieMaster)
not enough load on the flasher to operate, you do this 2 ways. easiest is to get a flasher meant for ir, or simulate a load on the circuit with a resistor
MIDNIGHTTUNER
Aug 19, 2014 12:34 PM
judd_123
Lighting
Feb 8, 2010 04:25 PM
phish4709
May 20, 2007 10:04 AM
