overheating VERY BADLY! :(
Old May 21, 2005 | 02:26 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default overheating VERY BADLY! :(
i got tje D15B2 and it keeps overheating BADLY. once it got up to the red and it blew out a O ring and the coolent shot out. i think it pushes it in to the coolent overflow tank but sucks air back in. today i filleded the radiator almost a liter and have had to add at least 1/2 liter evrey 3-4 days. the thermostat is brand new.
what could be wrong? i think i need a new cap.
Old May 21, 2005 | 02:44 PM
Redline130's Avatar
Default Re: overheating VERY BADLY! :( (DieMaster)
Are there any leaks from the hoses or radiator? Is your fan coming on? The cap could be the culprit too.
Old May 21, 2005 | 03:16 PM
DieMaster's Avatar
Default Re: overheating VERY BADLY! :( (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Are there any leaks from the hoses or radiator? Is your fan coming on? The cap could be the culprit too.</TD></TR></TABLE>
no no leaks. did the carbord under the car and it was clean. my fans do work. it does it regardless of driving (up hill or down, A/C on or off)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexwreck &raquo;</TD></TR><TR><TD CLASS="quote">if you keep having to add coolant, why aren't you assuming theres a leak? get a pressure checker to pressurize the system and see where it leaks. youll need an extra tiny one..</TD></TR></TABLE>
i did presure check it and the cap holds 11 lbs and the system holds 13 lbs for 10 mins.
Old May 21, 2005 | 03:24 PM
Redline130's Avatar
I think it's your cap. You must be burning off the coolant since there are no leaks from the motor. Unless your headgasket is bad. There's no coolant in your oil is there?
Old May 21, 2005 | 03:28 PM
DieMaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">There's no coolant in your oil is there?</TD></TR></TABLE>
no coolent in oil. and not burning it. i think it's spilling on the ground as i drive.
EDIT: also somthing i just noticed my overflow is filled beyond max when over heating but empty when cold. could my overflow have a crack in it?
Old May 21, 2005 | 06:38 PM
blah13's Avatar
Clogged radiator. If you have a new thermo and no leaks, no pressure loss, it has to be a slow restriction. Take your rad out and flush it or grab one from autozone...40-60 bucks.
Old May 21, 2005 | 08:17 PM
DieMaster's Avatar
Default Re: overheating VERY BADLY! :( (blah13)
i hit a dog a few months ago and they replaced the radiator. so it's brand new too.
i did notice that my hoses are starting to buldge. so i think new hoses and a new cap will fix it.
Old May 21, 2005 | 08:32 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
[QUOTE=DieMaster]i hit a dog a few months ago and they replaced the radiator. so it's brand new too.
u hit a dog? anyway check ur waterpump. guarenteed ur water pump took a ****.
Old May 21, 2005 | 08:34 PM
CRseXy's Avatar
it over heated? errrrrrrr, You arnt smoking are you??? if its not leaking, you might be burning it up.
Old May 21, 2005 | 08:39 PM
DieMaster's Avatar
Default Re: overheating VERY BADLY! :( (pogiTSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI &raquo;</TD></TR><TR><TD CLASS="quote">it over heated? errrrrrrr, You arnt smoking are you??? if its not leaking, you might be burning it up.</TD></TR></TABLE>
but theres no white smoke. so i cant be burning.
we just moved in to our new house on a hill with a great view. the car runs very hot going up the hill w/ or w/o the ac on.
Old May 21, 2005 | 09:08 PM
blah13's Avatar
Something that hasnt been mentioned is are you bleeding the coolant when you refill it? I would assume so but if not it certainly causes overheating issues. Otherwise look towards your water pump, other than that, a good pump/cap/thermo/rad/fans your **** should be ok.
Old May 21, 2005 | 09:28 PM
slowman's Avatar
I took way too long
yeah that overflow **** happened to me. i'm pretty sure it's your headgasket. about 4 months after that happened the headgasket took a complete **** on me. but i hope that's not the case for you!
Old Jun 1, 2005 | 03:33 PM
DieMaster's Avatar
Default Re: overheating VERY BADLY! :( (slowmanVTEC)
i replaced the radiator cap and havent had a problem yet mabye i got off lucky.
Old Jun 1, 2005 | 04:39 PM
Burlyirishdude's Avatar
if the waterpump went out...would it just lock up and squeel on the timing belt. I say it might be the WP.....check it out dude.... sorry but if it's the wp...you gotta do some lifting and take the cover off and replace it...
Old Jun 1, 2005 | 04:42 PM
ALLMOTA92EG's Avatar
yeah i just had the same problem first it was my lower radiator hose then my top so i said **** it and replaced them all including the heater hoses.
Old Jun 21, 2005 | 11:52 PM
05em2's Avatar
Default Re: overheating VERY BADLY! :( (Burlyirishdude)
so if water pump is not working... you will hear a squeeling from the belts? my car is overheating and i hear the squeeling!
Old Jun 22, 2005 | 03:51 AM
crx_88_si's Avatar
not always. check the upper and lower rad hoses for heat. if the pump is done one may be hot while the other still cold.
Old Jul 28, 2005 | 03:34 AM
StorminMatt's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">not always. check the upper and lower rad hoses for heat. if the pump is done one may be hot while the other still cold.</TD></TR></TABLE>
But the lower hose is ALWAYS cooler than the upper hose. This is a sign that your radiator is doing its job.
Old Jul 28, 2005 | 06:08 AM
b18_crx's Avatar
SO DIE MASTER WHATS THE UPDATE? was it ur radiator cap?
Old Jul 28, 2005 | 12:11 PM
DieMaster's Avatar
Default Re: overheating VERY BADLY! :( (b18_crx)
well it dosent do it as offen or as hot but after a hose burst at the market on a 112 degree day when iwas getting ice cream , i replaced both radiator hoses. it still gets over the thermometer symbol when driving up the hill to my house and i still have to add bout 1\2 a quart of coolent evrey few days. i defently made it less but the demon is still there.
EDIT: my overflow tank is fine, no cracks when i tool it out. and if the needle goes above the symbol then the coolent in the overflow boils.
Old Jul 29, 2005 | 04:44 AM
If you have severe overheating, disappearing coolant, no signs of leakage, and all cooling system components are good, then the most likely cause is a blown head gasket.
Old Jul 29, 2005 | 07:17 AM
SiMateoAko's Avatar
Default Re: overheating VERY BADLY! :( (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">If you have severe overheating, disappearing coolant, no signs of leakage, and all cooling system components are good, then the most likely cause is a blown head gasket.</TD></TR></TABLE>
That's what I'm saying.
Old Jul 29, 2005 | 10:35 AM
DieMaster's Avatar
Default Re: overheating VERY BADLY! :( (SiMateoAko)
but i'm not burning it. no white smoke out the back.
Old Jul 29, 2005 | 11:33 AM
deserthonda's Avatar
do a leakage test to see if head gasket is blown.........you might not see smoke out of tail pipe but still could have a blown head gasket
305S0L
11
Nov 8, 2019 08:04 PM
cilvia
Jul 4, 2008 10:21 AM
scoobyghost
Mar 28, 2007 05:18 PM
85Si-BBQGURU
10
Sep 8, 2005 06:37 AM
DFW
10
Jan 22, 2005 05:04 PM
