Need help with welding DP
Old May 21, 2005 | 02:20 PM
dannydos's Avatar
Default Need help with welding DP
hey what's up H-Ters..... well i use oxy-acetelene to braze copper lines at work ( im a hvac service technician ) I'm soon going to start my turbo project....and i need to do some welding with the down pipe....my ? is what kind of rod do i use with an oxy-acetelene setup. and what kind of flame do i want.....
Old May 21, 2005 | 05:12 PM
RCautoworks's Avatar
Default Re: Need help with welding DP (dannydos)
Can't help you with the rod
But for the flame, you want a bright blue flame and you want to get a puddle going, gas welding like that takes some control.
Old May 21, 2005 | 05:28 PM
dannydos's Avatar
Default Re: Need help with welding DP (90blackcrx)
bump for some more info
Old May 22, 2005 | 07:01 PM
dannydos's Avatar
bump
Old May 22, 2005 | 07:45 PM
BFC's Avatar
BFC
I use ER70-S2 for most O/A welding, it seems to work fine for me on cold/hot roll mild steel. As for flame, adjust to neutral, and go from there.
Old May 30, 2005 | 03:42 PM
dannydos's Avatar
Default Re: Need help with welding DP (BFC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BFC &raquo;</TD></TR><TR><TD CLASS="quote">I use ER70-S2 for most O/A welding, it seems to work fine for me on cold/hot roll mild steel. As for flame, adjust to neutral, and go from there. </TD></TR></TABLE> when using this er70-s2 rod is it the same thing as brazing with the brazing rod....pretty much just get the metal cherry red and then apply the er70-s2....
Old May 30, 2005 | 07:25 PM
EJAYATE's Avatar
I Deliver
No you have to get a puddle started. By that I mean the metal actualy hast to liquifiy sorta before you start dabing in the rod.
TIGboy
Welding / Fabrication
21
Dec 3, 2011 04:45 PM
22's and Man Boobs
Dec 17, 2007 07:48 AM
.john.
Sep 4, 2007 06:39 AM
HT Chaplain
31
Aug 7, 2007 06:41 AM
melovesboost
12
Apr 22, 2007 06:26 PM
