^^GARAGE SALE^^
obd0 Si-R B16 A/C compressor (spins free and clutch works) $25 and B series Starter $80
EF9 Si-R Stock intake tube and top of filter box $20
Obd1/2 A/C compressor same as the other one $25
B16 oil pan, lil dirty but will work fine $20
obd0 Si-R B16 intake manifold $20
Drivers EK upper control arm (used a little but ball joint still real tight) $15 EK fuel rail $10 obd2 dizzy, missing module $15 obd1 sohc rear mount $20
obd0 Si-R b16 Tranny mount $15 obd1 sohc and dohc tranny front mounts $20 each
D16y8 block ( needs to be bored, detonated) comes with block saver, crank, and arp studs. needs nuts and washers for the studs. you can but them direct from art for ~$30
Modified by funkfnamna at 11:42 PM 5/22/2005
"NastIE Built"
Jun 18, 2007 08:09 PM
