Aircon almost removed!
Old May 21, 2005 | 11:19 AM
ibme_uk's Avatar
Default Aircon almost removed!
Just spent the last 2 hours removing the aircon!!
I've managed to remove any trace of it from the engine bay including, pump, radiator, fan, something that goes next to the washer bottle and all the pipework right up to the join on the bulkhead behind the battary.
The only piece left in the engine bay is the aircon pump bracket that goes between the pump and the engine block. Can i remove it safely?
The reason I ask it cos it is connected to some kind of mount thats attached to the underside of the bodywork by the washer bottle.
Also any fuses I can pull to futher kill the system... i'm a bit worried about hitting the aircon buttom incase something shorts out.. (i've insulated the loom connector in the engine bay ).
Oh its alot cleaner looking now, less pipes to try and clean round!
Old May 21, 2005 | 11:44 AM
Micro's Avatar
Default Re: Aircon almost removed! (ibme_uk)
you cannot remove the A/C bracket, because it's connected to the drivers side lower engine mount. lol
There is a lightweight version of that bracket though... i think it came specifically in some newer model CRV's here in usa (it's an aluminum bracket)
Old May 21, 2005 | 01:05 PM
ibme_uk's Avatar
Default Re: Aircon almost removed! (Micro)
I thought the engine only had 3 mounts? one at each side and one at the back?
Old May 21, 2005 | 01:19 PM
B2FiNiTY's Avatar
It is a vibration mount. If you follow it, it is mounted to the bottom of the frame.
KEEP IT IN.
Old May 21, 2005 | 08:42 PM
d.n.d.'s Avatar
any pics? would like to see how it looks without A/C
Old May 22, 2005 | 02:12 AM
ibme_uk's Avatar
Default Re: Aircon almost removed! (drifter_X)
I'll sort one out... :-) Pics Below
Please excuse the state of the engine bay
Engine bay before
Engine bay after
Pump Mount
Something used to be here..
A/C Fan used to be here
A/C Radiator used to ber here... plenty of room to relocate the intake filter
Manifold where the A/C pipes were routed to the cabin
Modified by ibme_uk at 8:03 AM 5/22/2005
Modified by ibme_uk at 8:05 AM 5/22/2005
Modified by ibme_uk at 8:36 AM 5/23/2005
Old May 22, 2005 | 07:44 AM
p nut's Avatar
Does it not get too hot there? It gets up over 100 F here and I'm always sweating like a pig. Sometimes, I wish my car came with A/C
Old May 22, 2005 | 08:12 AM
ibme_uk's Avatar
Default Re: (P Nut)
No...if only..!!
Old May 22, 2005 | 12:32 PM
d.n.d.'s Avatar
Default Re: (ibme_uk)
lol cool pics wow so much more room now to work with btw i just noticed..ur car is RHD??
Old May 22, 2005 | 02:22 PM
Flux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibme_uk &raquo;</TD></TR><TR><TD CLASS="quote">... i'm a bit worried about hitting the aircon buttom incase something shorts out.. (i've insulated the loom connector in the engine bay ). </TD></TR></TABLE>
I removed the AC this winter. What you need to do is order Acura part #79612-ST7-023 (14 in diagram below). It is a blank that will fill the A/C button location. It will stop people from pushing it on hot days and finishes of the AC removal nicely...
Old May 22, 2005 | 03:38 PM
boostinCX's Avatar
Man, clean under that hood, lol. I wish i had a rhd R.
Old May 22, 2005 | 07:25 PM
KOALA YUMMIES's Avatar
Default Re: (boostinCX)
You're not done, you can pull out this thing too, its like a mini intercooler looking thing behind the dash.
Old May 22, 2005 | 10:13 PM
ibme_uk's Avatar
Default Re: (skylinedo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks, going to Honda today so will ask!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES &raquo;</TD></TR><TR><TD CLASS="quote">You're not done, you can pull out this thing too, its like a mini intercooler looking thing behind the dash.
Is there much more, not looked yet? also is it easy to tell what aircon and what heating etc.?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinedo &raquo;</TD></TR><TR><TD CLASS="quote">dude, is your teg RHD? I noticed the fuses, battery, brake booster/etc are on the other side. BTW looks as roomy as my RS
edit:
FYI: you're getting low on power steering fluid
Yeah imported the car from japan to uk last year, power steering fluid is getting flushed this week
Modified by skylinedo at 9:18 PM 5/22/2005</TD></TR></TABLE>
Old May 23, 2005 | 06:43 AM
Flux's Avatar
There is also weight to be saved by removing the A/C parts under your dash behind the glove box. Replace with a simple heater duct. Acura Part# 79810-SR3-A01.
Old May 23, 2005 | 07:01 AM
ibme_uk's Avatar
Default Re: (Flux)
Is that the same p/n for RHD?
Old May 23, 2005 | 07:26 AM
Flux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibme_uk &raquo;</TD></TR><TR><TD CLASS="quote">Is that the same p/n for RHD? </TD></TR></TABLE>
good question, not sure about that...
Old May 23, 2005 | 10:04 AM
Heh, probably not. I just noticed this was a RHD. Silly me. But yeah the behind dash A/C raditator thing sits in a black box thats separate from the heat, and if you replace the black box it bassically turns it from a big heavy box with the metal raditor into a thinner tunnel connecting the fan motor, to the heater core, and the rest of the ducting.
Old May 25, 2005 | 12:56 PM
ibme_uk's Avatar
Default Re: (KOALA YUMMIES)
Just incase there are any RHD people doing this mod, the part number for the switch cover is valid in the uk and the air duct is the same p/n but ends in 001 not A01 and fits a RHD teg..
Old May 25, 2005 | 04:24 PM
AMG's Avatar
AMG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ibme_uk &raquo;</TD></TR><TR><TD CLASS="quote">I thought the engine only had 3 mounts? one at each side and one at the back?
2 on each side + 1 in the rear = 5.
Old May 25, 2005 | 05:04 PM
Chiller's Avatar
To remove the AC button i just stuck on a piece of electric tape over the A/C light and no one even questions it.
The AC fan is on the drivers side correct and only is used for AC?
Old May 25, 2005 | 05:27 PM
Haleiwa-Brando's Avatar
Default Re: (Chiller)
I have done this full removal also. Len was nice enough to help me do it in his driveway . I've had cars with A/C. Never used the systems. I figured since I'm a 5'8" skinny *** *****, I know I get cold easy enough....why do I need A/C? Rolling down the windows at speed is good enough for me.
Nice work!
Old May 25, 2005 | 07:30 PM
1993sir05's Avatar
why do u have a type r?
Old May 25, 2005 | 07:41 PM
Reid's Avatar
Global Moderator
Default Re: Aircon almost removed! (1993sir05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993sir05 &raquo;</TD></TR><TR><TD CLASS="quote">why do u have a type r?</TD></TR></TABLE>
Probably because he wanted one.
I find that's a common reason for owning an ITR.
Old May 25, 2005 | 08:01 PM
1993sir05's Avatar
Default Re: Aircon almost removed! (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
I find that's a common reason for owning an ITR. </TD></TR></TABLE>
yeah me too, and if you werent a mod, would you be banned with that smart mouth of yours.
Old May 25, 2005 | 08:02 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993sir05 &raquo;</TD></TR><TR><TD CLASS="quote">yeah me too, and if you werent a mod, would you be banned with that smart mouth of yours.</TD></TR></TABLE>
I don't have a smart mouth, you simply asked a stupid question.
In case you forgot, you asked this:
Does that make any sense to you?
