Intake manifold question??
Old May 21, 2005 | 09:04 AM
99RedSi's Avatar
Default Intake manifold question??
I recently bought and installed a 69mm throttle body and installed a port matched intake manifold as well. I changed my mind and want to go with a smaller one because this one i think is to big. My question is, can i put my stock throttle body onto the ported intake manifold or do I have to put the stock manifold back on as well???
Old May 21, 2005 | 09:42 AM
99RedSi's Avatar
Default Re: Intake manifold question?? (99RedSi)
Anybody?
Old May 21, 2005 | 11:12 AM
Suck my DX's Avatar
u should port match them..or else u wont see any real gains
Old May 21, 2005 | 11:24 AM
NJIN BUILDR's Avatar
You will be fine using stock tb on ported manifold.
Glenn
Old May 21, 2005 | 03:36 PM
chris_m's Avatar
* B A N N E D *
Default Re: Intake manifold question?? (NJIN BUILDR)
did you already install the bigger tb? You can reuse the stock tb just make sure to use a new gasket
Old May 21, 2005 | 08:44 PM
99RedSi's Avatar
Default Re: Intake manifold question?? (Christopher M)
Thanks for the info guys, yeah i already installed the 69mm throttle body. I think i'm going to go a little bit lower like a 62mm or something. The 69mm is kinda slugish in lower rpms.
DOHCED8
Oct 16, 2011 05:27 PM
Ek-Xang
Oct 20, 2010 01:40 AM
Shizznaz
Jun 19, 2005 10:52 PM
JforJonathan
10
Apr 10, 2004 12:15 PM
TurboB18C1
May 19, 2003 05:08 PM
