endyn
Old May 21, 2005 | 08:03 AM
White_EK49's Avatar
Default endyn
anybody has this problem. the catch can has a lot of vapor coming out of it. the car is ls turbo with the endyn setup. all hoses are hooked up correctly according to the schematic. Oil comes out of the moroso filter only after a hard 1/4 mile run. This seem unusual. Does it have too much blowby. The piston rings are filed to spec. Clearance on piston to wall is perfect. Thanks
Old May 21, 2005 | 09:48 AM
B20TDC2's Avatar
Default Re: endyn (slow29)
make sure your drain is at a downward angle , alot of people were having the problem above 15psi , it turns out the drain was the problem . i have no problem with mine and i run my car hard on highway runs in excess of 1/4 mile
diatibe24
Oct 10, 2016 01:01 PM
mylsspecteg
May 21, 2006 03:22 PM
