Complete All Motor Car ***CHEAP***
This car is flawless. The body is in perfect condition with many hours in prepping for paint. Its ready for what ever color paint you want!! Turn my dream car into your dream car. The CRX has a clean title. The car had one ding on it and that was it, no major bodywork was done. The interior is also ready and prepped for what ever your plans call for when it comes to a roll bar or a roll cage.
The motor set up went 12.2s at 1950LBS with the clutch slipping. This car and set up has potential to go high 11s tuned and driving correct. I have attached a copy of a dyno run.
****Asking 5,000 Make me a reasonable Offer and Its yours*********<U></U>
Chassis
91 Honda CRX SI (Race Only)
Wings West fiberglass rear bumper molded
Wings West fiberglass side skirts molded
Wings West fiberglass door caps molded
Door handles are off a four door coupe No Key Hole
Doors are cut out
1 piece MB Products front end
All windows are FAL Lexan
Body modifications are sunroof, rain gutters, gas door and rear wiper hole are shaved (welded plates)
Interior
Kirky aluminum race seat with black cloth cover
Simpson five point race belts
Spacro steering wheel with two push buttons and cords
Place Racing Shift Linkage
Skunk 2 Short Shifter
Skunk 2 Shift ****
The rest of the interior is gutted
Suspension
All suspension is off a 98 GSR. Disc brakes all around with cross drilled rotors
Koni yellow shocks
Skunk 2 coilovers
Skunk 2 extended wheel studs
After market Rear lower control arms
MB Products front cross member
Rims and Slicks
Bogart’s Drag-On Flys
Front M&H 22x9.5x13 (two passes on them)
Extra set unmounted of Mickey Thompson 24.5x7.0x13 (one dyno pass on them)
Rear M&H Skinnys 24.5x3.0x15
Motor
B16 LS/Vtec
JG Pro Series Head (all the goodies top notch)
JG All Motor 316 Cams
Block has Civic Type R Pistons and Rods
Skunk 2 Intake
STR Fuel Rail
RC 310 Injectors
AN-R Side Exit Header
ACT Streetlite Forged Flywheel PN # 600110
ACT Heavy Duty Pressure Plate PN # H-025
ACT 6 Pad Race Disc PN # 9P220J (Brand New)
Transmission is a B16 Cable with the diff Welded
Everything Listed Below Also Comes With the CRX
P28 Skunk 2 Racing ECU Serial # 37820 P28 A02 760 743220
P28 Custom Wire Harness (Race Only)
Moroso Dashboard & Rollcage Mount Switch Panel with Push Start and Fuses
Autometer Pro-Comp Ultra-Lite 2 5/8 Mechanical Gauges:
Fuel Pressure
Volts
Oil Temp
Oil Pressure
Water Temp
Autometer weld in adapter PN#2261
Custom Wire harness for the Autometer Gauge Lights
92-95 Civic Radiator OEM (Brand New)
Aftermarket Thin Radiator Fan
1 Gallon Jaz Pro Fuel Cell (Black)
Battery Box (weld in 7x10)
Paxton Fuel Filter
MSD Fuel Pump
Braided Lines & Fittings (many extras)
MSD Launch Control With 3 Step (tune from the starting line)
Biondo Linelock/Roll Control
Positive & Negative Remote Terminals
Jaz Overflow With Filter
Deist Custom Window Net
Energy Suspension Bushing Kit
AEM Intake Piping & Filter
Extra Intake Filter
Extra Throttle Linkage
Goodridge Rear Braided Brake Lines
Venom Radiator Cap Cover (Dress Up)
Venom Brake Master Cap Cover (Dress Up)
Exhaust Gasket (Brand New)
1 Box NGK R5671A-8 Spark Plugs
2 Fram Oil Filters PH3593
RLCR Off GSR With Energy Suspension Bushings
2 Extra Clutches (used one run each)
Stock Flywheel
Stock Oil Pump
Stock Fuel Rail
Stock Throttle Body
Stock Brake Master
Stock Vacuum Box
2 Extra Half Shafts
Extra Pulley
I have probably missed a few items. As you can see there is a whole car there that just needs to be put back together. If you have any question feel free to call me (707)338-1533 or E-mail me reddog78@sbcglobal,net at any time.
Chassis
Doors are cut out
Interior
Skunk 2 Shift ****
Suspension
Koni yellow shocks
Skunk 2 coilovers
Rims and Slicks
Motor
B16 LS/Vtec
Skunk 2 Intake
STR Fuel Rail
RC 310 Injectors
Fuel Pressure
Volts
Oil Temp
Oil Pressure
Water Temp
Paxton Fuel Filter
MSD Fuel Pump
Extra Intake Filter
Stock Flywheel
Stock Oil Pump
Stock Fuel Rail
Stock Throttle Body
Stock Brake Master
Stock Vacuum Box
2 Extra Half Shafts
Extra Pulley
denraweb
21
Apr 29, 2012 05:13 PM
cor4ey
May 8, 2009 11:53 AM
hammerdgolfer
May 23, 2004 08:02 AM
pdiddyparsons
Apr 6, 2003 10:12 AM
