Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Suspension question Guru's
Old Feb 6, 2002 | 02:17 AM
B18C-EJ1
Guest
Posts: n/a
Default Suspension question Guru's
How does one figure which spring rate to use on any given car?
For instance, if your car weighs 3000lbs, and it's a 60-40 weight, how do you figure which springs to use?
Or, is it just an educated guess?
TIA
Old Feb 6, 2002 | 05:30 AM
MechE00's Avatar
Default Re: Suspension question Guru's (B18C-EJ1)
Best to find out what other people using the same car for the same purpose are using..
The reason I say this is that suspension geometry can change the effective "wheel rate" or spring rate at the wheel, for a given spring. On a Honda civic, a 1000 pound spring is rattle your teeth on the street, but due to mustang suspension geometry, it's not really a big deal (if I remember my facts correctly).
Also, obviously, FWD vs. RWD matters too..
and again, obviously, it depends on the application (road race, daily driver, performance rally, autocross)
In the end, the answer to your question for most people is "educated guess with trial and error" (hopefully you can make use of other people's trial and error). That said, the "learn from what other people do" tactic is probably much more sane when you get to the world of competition drivers, as opposed to the "Yo! TiZzItE! ShIzNiT!" crowd. In the competition crowd, you can evaluate their skills and their performance with their car to get an idea of their credibility.
Old Feb 6, 2002 | 08:59 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
to get the best rates it's ultimately trial & error and datalogging/checking the results and driver's feedback.
you have to specify the general environement to start with to get into the ball park.
bump or smooth track, what type of tires, any down force, type of racing... etc. and work from there.
Old Feb 6, 2002 | 10:20 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Suspension question Guru's (frank@b16a.com)
Ok, well here's my thoughts. I mostly drive on the streets, but I love to hit the local mountians and tear up some asphault. I intend on going to some track days here in SoCal when they open.
About my car-
95 Civic coupe hybrid GSR.
LSD equipped tranny
24mm front bar (soon to be 26 if necessary)
22mm rear bar
all energy suspension bushings
I'm considering these 2 spring rates.
F- 448
R- 280
Or
F- 448
R- 336
I can also do...
F- 392
R- 168
But I think that's too soft of a spring.
Any recommendations?
[Modified by B18C-EJ1, 11:21 AM 2/6/2002]
Old Feb 6, 2002 | 11:35 AM
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
If you are SERIOUS about it,I would get the car "corner weighted." You've obviously made some driveline changes that will have effectively changed the stock suspension geometry anyway.
My buddy Loren just installed a FULL Penske adjustable system on his car,somewhere around $10k?
But he can change virtually every aspect of the suspension now.
I usually go with a harder than normal spring rate and use a slightly softer dampner setting,it helps offset the "bone chattering" associated with stiffer spring rates.
Old Feb 6, 2002 | 12:06 PM
Banned
I can tell you I'm very happy with my budget setup. Rides firm on the streets, but still comfy. And works quite well on the track. Even pro driver Rhys Millen had compliments for it, noting only lack of power, it is just a 1.6 after all. But it holds it own quite well.
http://g-speed.com/eg2/mods
Old Feb 6, 2002 | 12:18 PM
El Chico
25 Year Member
Community Builder
Well,I'll say this,for MOST applications,a budget street set-up is more than enough.
You'd just have to know Loren to see why spending $10k on his SoloII Miata,sounded like a good idea. He never half way does anything.
I am from the school of thought, "do only as much is nescessary." This way you're not to broke to go celebrate afterwards. lol
beefjerky
Oct 10, 2005 09:30 PM
Jason C SBB
Aug 5, 2003 06:48 PM
01silverteg
Mar 15, 2003 07:54 PM
itr1236
Mar 6, 2003 09:13 PM
MrBite
Dec 10, 2001 12:04 PM
