Type R suspension on GS-R lower control arms, will it fit?
Old May 20, 2005 | 04:40 PM
alfaaay's Avatar
Default Type R suspension on GS-R lower control arms, will it fit?
I'm getting a great deal on some coilovers for my car. I was under the impression that GS-R rear LCA's and Type R rear LCA's are different, so will these coilovers work, or do I need to change LCA's? If so, does anyone know where I can find some? JHP carries OMNI LCA's, but they're listed application is "eg / dc" ... so I don't know if those are the right ones.
Old May 20, 2005 | 04:46 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Type R suspension on GS-R lower control arms, will it fit? (alfaaay)
You'll need to get ITR LCA's as they are different from GSR's. Try Password JDM and see if they have any used OE ITR lca's for sale. Or do a search for ITR lca's in the classified's.
Old May 20, 2005 | 04:59 PM
veggiemaster's Avatar
you just need Type R LCA's, if you want to go the bling omni route, then get the type R LCA's, they will bolt right up.
Old May 20, 2005 | 05:22 PM
alfaaay's Avatar
Default Re: Type R suspension on GS-R lower control arms, will it fit? (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">you just need Type R LCA's, if you want to go the bling omni route, then get the type R LCA's, they will bolt right up.</TD></TR></TABLE>
I like the Omni design, the stars are goofy, hahaha. I don't get it though, they make a "eg/dc" model, but they don't specify a dc-r version. hmm....
Old May 20, 2005 | 05:58 PM
DC2-JRSC'd's Avatar
or get the lca from an 88 CRX they are the same as the type r and usually much cheaper
Old May 20, 2005 | 06:47 PM
Gee3's Avatar
Default Re: Type R suspension on GS-R lower control arms, will it fit? (DC2-JRSC'd)
I thought I read on h/t that the CRX lca's are slightly different... May want to check on that first.
Old May 20, 2005 | 06:55 PM
alfaaay's Avatar
Default Re: Type R suspension on GS-R lower control arms, will it fit? (Gee3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gee3 &raquo;</TD></TR><TR><TD CLASS="quote">I thought I read on h/t that the CRX lca's are slightly different... May want to check on that first.</TD></TR></TABLE>
I don't think I'd be doing that anyway... even if they did fit, wouldn't they have much less structural integrity? It'd be ironic to upgrade to a nice suspension and downgrade the LCAs
Old May 22, 2005 | 10:12 AM
DC2-JRSC'd's Avatar
The only difference between the crx lca and type r is the coating that comes on them and the crx hole is slightlly smaller not not by much to make either shock not fit.
As far as the less structural integrity comment. I know they are lighter then the normal LCA's and I think also stonger. If they were weaker i dont think they would use them on most hondas in japan. I could be wrong.
Old May 22, 2005 | 10:18 AM
Johnny Gasparini's Avatar
I didn't ask for a dime.
I think I have seen R LCA for $99, new. Try JHPUSA and Password as mentioned.
iheartDc2
Feb 18, 2006 08:02 AM
Axel Foley
Suspension & Brakes
11
Jan 11, 2006 02:11 PM
opiumdaze
Sep 16, 2005 04:27 PM
92integ
Feb 17, 2003 04:55 PM
civh
Aug 13, 2002 10:21 AM
