looking for info on si swap going into hf, haveing problems
Old May 20, 2005 | 12:54 PM
fullraceacura's Avatar
Default looking for info on si swap going into hf, haveing problems
i dont know how to search for hf si swap since you have to have 3letter words
but a freind of a freind put a si engine/engine harness into a hf and i told him that the si/hf harnesses are different right? does anybody have some info on what you have to change for this, thanks alot
Old May 20, 2005 | 02:41 PM
d16efsedan's Avatar
Default Re: looking for info on si swap going into hf, haveing problems (itr#xxxxlives)
i think they are the same except the EGR plug.not positive on that though...
Old May 20, 2005 | 04:22 PM
JohnnieChimpo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16efhatch &raquo;</TD></TR><TR><TD CLASS="quote">i think they are the same except the EGR plug.not positive on that though...</TD></TR></TABLE>
Not only are the HF and Si not the same but the harnesses are different through the years too, 88 is one harness, 89 is another and 90-91 is a 3rd harness.
Tell your buddy to peel the HF harness off the HF motor and put it on the Si engine. Like the other guy said you'll have an EGR plug, just let it hang.
Pop in the Si computer and you should be fine.
I spent about a week tracing every wire on my HF harness and I even used another HF harness, just different years.
Old May 24, 2005 | 09:49 AM
401B20CRX's Avatar
i have a question, im doing what itr#xxxxlives is doing but its the other way around, i got a HF body and HF moter, but i have an SI ecu and the whole harness wires from the SI dash wired up on my crx, it wont start up, it cranks up but no start up? do i have to use the si engine harness too...?
89loudcrxsi
Apr 7, 2008 11:25 AM
peiku
Feb 21, 2006 03:10 PM
EK FLY
Oct 8, 2005 07:36 AM
91HATCH
23
Oct 15, 2002 05:03 PM
Tbone
Jun 18, 2002 01:34 PM
