HELP!! Checking codes for 93 Si wiring?
Old May 20, 2005 | 12:32 PM
Solice's Avatar
Default HELP!! Checking codes for 93 Si wiring?
Went to look for plug to check what code (if any) I'm running. According to JDMLyfestyle, https://honda-tech.com/zerothread?id=1171263, there should be a black/white and red/black wire coming from a grey plug down by the ecu. I cannot find it.
I've looked under the carpet, took the glove box off and checked behind that....and I still can't find it.
Is it a possibility that the wiring from an SI made in Canada would be different than another EG? Is there some trick to finding this wire that I haven't found? Please help. Thanks.
Old May 20, 2005 | 09:09 PM
Simple's Avatar
Default Re: HELP!! Checking codes for 93 Si wiring? (Solice)
looking in the wrong place... run your hand along the under side of your dash on the passenger side just right of the glove box... reach up there and grab the green rubber plug holder, pop out the 2 pin plug, and jump the two together, search and you can easily find pictures of this process... but thats a quick rundown
Old May 21, 2005 | 10:26 AM
Solice's Avatar
Default Re: HELP!! Checking codes for 93 Si wiring? (Simple)
I found the wires I needed. They were actually the first wires I found up in there. The thing was though, that everything I'ver read said that it was a grey or white plug, with black/white and red/black wire. Thing was, it was a blue plug, with a blue and brown wire. And since i never had my check engine light on at the time, it never registered any codes at the time.
Thanks for the reply though!!
maybe you can help me with my other post....
https://honda-tech.com/zerothread?id=1253042
Old May 21, 2005 | 10:33 AM
Morning Call's Avatar
yeah i had same problem.. colors dont match.. but i figured it must be the blue plug
i jumped it, and my check engine light was solid so i assume i dont have any codeS?
sammyboy1978
Honda CR-V & Element
Mar 4, 2012 10:22 PM
1SlowSi
Jul 26, 2009 11:34 AM
johnwohl
Jan 25, 2008 11:20 PM
PINKS
Welding / Fabrication
Mar 3, 2007 02:35 AM
crx_91si
Jul 25, 2001 07:06 PM
