stock cam specs
Hey guys, I was doing a little research and was curious about the stock cam specs for the s2000, mid lobe was my main concern. I've been unable to find this information googling. Does anyone have any idea what they are?
Thanks
Thanks
Thanks for the info guys, but I think I'm still at square one. I was ultimately looking for the duration and valve lift of the mid lobe. The manual lists total lobe height, and by the large number it would have to be including the base circle diameter.. i.e the diameter of the entire camshaft not just the lift.
If someone could tell me the base circle diameter I could subtract that from the cam lobe height to find lobe lift. And assuming the rocker ratio is 1.5 multiply that by the lobe lift to find valve lift.
It seems like stock s2000 cam specs are among the best kept secrets on the planet, heh heh. Oh well, I'll keep searching.
Thanks for your help guys.
granracing
Feb 18, 2005 02:54 PM
