b20 crank b16 block
Old May 20, 2005 | 11:46 AM
xDicktonesx's Avatar
Default b20 crank b16 block
i won a b20 crank on ebay for really cheap. is anyone runnign a b20 crank with a b16 block annd some odd sized rods? if so what size are the rods? i read something on the internet about a set up liek this from crower sporting 12:1 compression. just want to know if its possible and if so, with what rods?
Old May 20, 2005 | 11:47 AM
Kendall's Avatar
Look up a company called Tech43 Racing.
Old May 20, 2005 | 01:06 PM
B-Hatchie's Avatar
Default Re: b20 crank b16 block (CRXofPain)
i could be wrong but a b20 and b18b crank are the same thing so you could use ls rods(oem or after market). But there could be an issue with deck height. but dont take my word on that. Somebody want to chime in on this?
Old May 20, 2005 | 02:05 PM
onepoint6i's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Look up a company called Tech43 Racing.</TD></TR></TABLE>
Old May 20, 2005 | 02:07 PM
D-Rob's Avatar
Default Re: b20 crank b16 block (B-Hatchie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-Hatchie &raquo;</TD></TR><TR><TD CLASS="quote">i could be wrong but a b20 and b18b crank are the same thing so you could use ls rods(oem or after market). But there could be an issue with deck height. but dont take my word on that. Somebody want to chime in on this?</TD></TR></TABLE>
Bingo.
Your pistons will be through your head.
Tech43 (as previously mentioned) uses custom pistons with a raised wrist pin location (I would assume) to allow the LS/CRV crank/rods to be fitted into a B16 block.
If I had the patience/money, I'd be all for a 1.9 liter motor stuffed into a 1.6 liter-stamped block.
...Instead I'm taking the easy route and going LSVTEC.
Old May 22, 2005 | 08:01 PM
Default Re: b20 crank b16 block (D-Rob)
ok..so i got the crank. this will make you maybe a lil jealous but i payed 15 bucks for it. and yes..its straight. BUT i belive its from a 2liter prelude. although he siad its what eagle uses for their b series stroker kits. what mods need to be done to crank to make it work for the b series? i plan on balancing and knife edging it becuase i got it so dirt cheap.
and the part about the 1.9L with a b16a stamp on the block....that is EXACTLY what im trying to accomplish here.
a buddy of mine has told me that endyne makes pistons specifically for this application with a relocated wristpin location.
side note: what 02 sensor am i supposed to buy with an obd0 b16a? theres only one correct? precat if im not mistaken.
i contacted crower and they told me that with their kit i would have a 12:1 CR. sounds great but i dont think california **** fuel would atomize very well with comp like that.
so..if this is the 'lude crank..what do i need to do to make it work? and for an all motor app...h beam rods or a-frame? anyone sell balanced sets?
im also going to be worried about cam selection with the whole valve to piston clearance issue but ill worry about that later on. thanks for your help.
Old May 22, 2005 | 09:02 PM
5thgenallmotor's Avatar
I think that the prelude b20 crank is different. It can work with some work. I think for one the timing belt gear does not aling properly. Do a search for b20a cranks. I know i have read about it before. Good luck!
Old May 22, 2005 | 09:08 PM
HondaIntegraR's Avatar
Default Re: b20 crank b16 block (5thgenallmotor)
i thought the old prelude cranks were like 95 mm, correct me if im wrong please
Old May 23, 2005 | 03:04 PM
Default Re: b20 crank b16 block (HondaIntegraR)
the crank is in the mail. ill wait until it gets here to see if there are any identifiable marks on it.
edit: found that b20acranks are either 94mm or 95mm via the search. i emailed the tech43 guy. we'll see if he emails me back
Old May 23, 2005 | 03:54 PM
Combustion Contraption's Avatar
use the longest rod you can stuff in that block, youll thank yourself later.
Old May 23, 2005 | 04:04 PM
philafelman's Avatar
Default Re: (LsVtec92Hatch)
the thrust bearing location is diff. the block will have to go to a machine shop to fix that, and i think you have to use custom length rods and pistons.
Old May 23, 2005 | 05:32 PM
Default Re: (philafelman)
anyone have absolute specifics on what needs to be done to the block? or where i can find them?
i already found a guy thats going to balance and knife edge it for me. not trying to rev to 10,500, i just dont want longevity issues, which is why im worried about valve to piston clearance as well.
if the block is goign to be at the machine shop what is the biggest bore i can go without sleeving?
nice numbers up there at 212/156.. 81mm bore and 89mm stroke, isnt that a b16 block and an b18a/b crank?
Old May 24, 2005 | 07:43 AM
Default Re: (CRXofPain)
anyone know what needs to be done to the block and crank? tech43 never contacted me back. anyone else make kits? preferably other than $poon.
Old May 25, 2005 | 09:52 AM
TECH43 RACING INC.'s Avatar
email replied:
As far as using a 95mm crank in a b16a block, bad idea. The deck height is not tall enough to be able to fit in a decent lengthed rod. In a b16a block,fitting the ls crank/rod is about as good as it gets with a full ring pack.
Also, those b20 prelude cranks are not very strong, and problems can occour down the line with the snout. If you want to use a 95mm crank, I would suggest using an aftermark unit ie: eagle, scat, or having a crank shop increase the stroke on an ls 89mm crank. Using a b18 block is gonna be your best bet so you can fit a decent rod in it to make it live. I do offer piston/rod kits for 95mm cranks in b18 blocks.
You also might want to think about using a 92mm crank. Its right in between the ls and 95mm stroke. Best of both worlds maybe. Let me know if you have any additional questions.
Thanks, steve
Old May 26, 2005 | 09:15 AM
Default Re: (TECH43 RACING INC.)
i replied via email
feriotypeR
Jul 23, 2008 08:45 PM
iloveb16
Aug 6, 2007 10:05 AM
5w20
Dec 4, 2004 11:57 PM
pootie.teng
14
Aug 25, 2004 04:50 PM
cyrock
Aug 5, 2004 06:26 PM
