Putting in a mechanical oil pressure gauge
Old May 20, 2005 | 10:44 AM
sirwags's Avatar
Default Putting in a mechanical oil pressure gauge
I need to test the oil pressure to the head. Some say the oil pressure gauge replaces the spot for the oil pressure switch next to the VTEC solenoid. Others say the small fitting to the left of the solenoid can be used. Anyone break it down for me? including what type and size adapter i need? thanks
Old May 20, 2005 | 01:44 PM
xbn83's Avatar
Default Re: Putting in a mechanical oil pressure gauge (sirwags)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirwags &raquo;</TD></TR><TR><TD CLASS="quote">I need to test the oil pressure to the head. Some say the oil pressure gauge replaces the spot for the oil pressure switch next to the VTEC solenoid. Others say the small fitting to the left of the solenoid can be used. Anyone break it down for me? including what type and size adapter i need? thanks</TD></TR></TABLE>
What engine? I have a H22, the factory oil pressure switch is under the oil filter.
Old May 21, 2005 | 09:53 PM
sirwags's Avatar
Default Re: Putting in a mechanical oil pressure gauge (xbn83)
it's an H22-99 prelude SH. I cant use the normal oil pressure switch area because i need to check the pressure to the head not the block.
Old May 22, 2005 | 02:19 PM
sirwags's Avatar
I tried the port next to the vtec solenoid towards the intake manifold. I have an auto meter gauge and it comes with the 1/8 fitting, but as soon as i began to screw it in it becomes hard. I didnt try to use a ratchet because i didnt want to mess up the threads in the motor. Is it normal for the fitting to not screw very easily?
Old May 22, 2005 | 02:29 PM
Eddiebx's Avatar
all the fittings on the head are metric, ur gonna need an adaptor
Old May 29, 2005 | 09:55 AM
sirwags's Avatar
Default Re: (Eddiebx)
I got the mechanical oil pressure gauge in and setup: no leaks or kinks in the line. The instructions dont mention bleeding the line so i didnt, so there is obviously air in the line but pressure is pressure, so the gauge should still read, right? I dont see how you would bleed it anyway because the line is in your car so. Also, the small port next to the VTEC solenoid should work right? not the oil pressure switch, the port on the opposite side of the solenoid
thanks
Old May 30, 2005 | 09:48 AM
DcWest's Avatar
Default Re: (sirwags)
if you screwed it into the side of the head the fitting is a 1/8" bspt not npt fitting.
Old May 30, 2005 | 10:07 AM
PrecisionH23a's Avatar
Default Re: (DcWest)
The oil pressure sending unit port is also a 1/8" bspt
lude98SH
Jan 13, 2008 06:58 AM
Mr HYDE
Mar 29, 2007 06:02 PM
DOHCarp
Apr 29, 2005 04:19 PM
bosco500
Apr 5, 2005 03:57 PM
scarecrow
Mar 7, 2005 10:26 AM
