My LS\Vtec build
My build
B16a Head w/ GSR cams
B18b Block w/ PR3 pistons mounted on stock ls rods
Here's my parts list thus far:
Golden Eagle LS\Vtec kit
PR3 Honda OEM Piston Ringset
ACL Bearings
Golden Eagle Head Studs
ITR Oil Pump
ITR Water Pump
ITR T-belt
ARP Rod Bolts
ITR Intake Manifold
B18b TB bored by maxbore
Once I get a little more cash I plan on upgrade my valvetrain also.
My B18b1 block.
Adios crappy ls head (ignore the white eg in the back... it's not going in that)
Removing the B18 rods
B18 rods and pistons on top B16 rods and pistons on the bottom.
My pistons back from the machinist. They really turned out great!
Throttle body bored by Jorge at Maxbore. Bored to 64mm.
Golden Eagle "HD" Headstuds w/ glass bead finish
New oil pump, water pump and tensioner installed
Old B16 ..... pulled
PR3 pistons installed w/ new rings in freshly honed cylinders
Rebuilt tranny mounted on b18 bottom end and installed
Head finally installed
A lot of little things to finish up but for the most part she's in!
It's sitting a bit higher than the B16 that was in there before. Looks like I'll be cutting the hood a little.
Slicks and rims finally came too.
ACL Bearings
ITR Oil Pump
ITR Water Pump
ITR T-belt
ARP Rod Bolts
ITR Intake Manifold
My B18b1 block.
nice build! you shouldn't have to cut the hood, i didnt on my ls/vtec in my 91 hatch, i used hcp mounts. it is very close though, if i run my plug wires across the top of my valvecover, and not in the recessed area, they come in contact with the hood.
Thanks for the compliments, the motors running great so far. I just started breaking it in last weekend. I can't wait till I can push it harder! One bad thing is that the rebult tranny that I bought... well.... it's needs to be rebuilt again. 3rd and 5th grind and 4th keeps poping out of gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote">is it just me or is the ls valve cover slanted down? look.</TD></TR></TABLE>
It's not a ls valve cover it's a b16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloS13 »</TD></TR><TR><TD CLASS="quote">
BTW - **** you for having a garage
ha ha notice the gas heater in the background, I installed that last Christmas..... oh so nice in the fall and winter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy »</TD></TR><TR><TD CLASS="quote">Are you using GE's LS/VTEC oil kit?</TD></TR></TABLE>
yup
Modified by miller.91.HB at 10:56 PM 5/22/2005
yup
How is it running so far?
