HCP mounts - driving me crazy
Old Feb 5, 2002 | 08:59 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default HCP mounts - driving me crazy
No i have nothing bad to say about them yet , but MY GOD are they solid!! The entire car is buzzing with resonance now- is there anything i can do to combat it? I have all 4 mounts installed too, im guessing it wouldnt be quite as harsh if i took off the front one, correct? When its idling and you have the hood popped its as if the motor isnt even on its so still. Its liveable, but for reference it makes the car louder inside than an ITR on the freeway when you are cruising.
-Todd
Old Feb 5, 2002 | 09:05 PM
Blown90hatcH's Avatar
Default Re: HCP mounts - driving me crazy (GymkhanaGTI)
Welcome to the world of eurathane mounts. All of the mount kits out there running the eurathane have some sort of vibration to them.
Old Feb 5, 2002 | 09:18 PM
B16A1-EF9's Avatar
Default Re: HCP mounts - driving me crazy (Blown90hatcH)
I have the HCP mounts and I love them! Don't really mind the vibration.
Old Feb 5, 2002 | 09:22 PM
MysteryWagon's Avatar
Default Re: HCP mounts - driving me crazy (bandit_sir)
woo hoo!!! HCP for ever they are the poo poo. Plus it makes your car fill more like a beast.
Old Feb 5, 2002 | 09:47 PM
wickedxboi's Avatar
Default Re: HCP mounts - driving me crazy (ShaggenWaggon)
dont worry........give it like a month.......they'll ride a lil bet smoother
Old Feb 6, 2002 | 01:53 AM
JDM_DOHC_SiR's Avatar
New User
Just make sure to check all your fasteners and bolts & nuts to make sure you haven't lost any from the vibration j/k
Old Feb 6, 2002 | 03:13 AM
TypeR0207's Avatar
Default Re: HCP mounts - driving me crazy (JDM_DOHC_SiR)
Well since I was used to drive a Type R with i/h/e and bouncing from being on 17's and lowered, if it sounds like that, I'll be happy!!!
Old Feb 6, 2002 | 07:39 AM
89HF's Avatar
New User
I have the mounts,too,so here's my 2 cents-you're going to have more vibration than stock no matter what because of the urethane.I wouldn't remove the front mt-it's there for a reason and that's the way Honda does it.Look at the rear mt.Notice the large diameter?Does the mt. touch the firewall?If it does,a lot of your extra vibration could be coming fom this.You can dent the firewall(carefully)for clearance like you had to do your left frame rail for the alt. pulley.I know this is impossible w/the motor in the car.I plan to pull my B16a when I install my GSR YS1 and clutch(much easier w/the motor out!)and I am going to dent my firewall and my left frame rail for some more alt. pulley clearance(it's really close right now).I'll let every one know if this helps w/the vibration-I think it will.
Old Feb 6, 2002 | 01:47 PM
internet ay's Avatar
Default Re: HCP mounts - driving me crazy (89crxb16a)
my hasport mounts vibrated the shifter **** off of my shifter twice.
Old Feb 6, 2002 | 02:09 PM
rioninja's Avatar
Here's a trick:
instead of torquing the motor mount bolts to 50ft lbs, torque them to fifteen or twenty. Then put locking nuts on the end of each bolt. Make sure you properly torque the locking nuts.
Also, check the front mount to make sure its not rubbing against the crossmember.
Old Feb 6, 2002 | 08:45 PM
Default Re: HCP mounts - driving me crazy (internet ay)
Sweet
Old Feb 6, 2002 | 09:22 PM
1st-hybrid's Avatar
Can't wait to order my HCP mounts next week I'm going to make the order.
Old Feb 7, 2002 | 08:10 AM
EL Vap133's Avatar
Default Re: HCP mounts - driving me crazy (1st-hybrid)
The only time I can hear vibration from my Rex is when I have chenge in my ashtray, but I used The Place Racing mounts though.
Old Feb 7, 2002 | 08:31 AM
SiR Kid's Avatar
New User
Default Re: HCP mounts - driving me crazy (Vap133)
My car vibrates like NUTZ. Worst when the car and the eurethane is cold and it's idling about 1800 RPM. SUCKS. I always think my engine is coming apart on me
Old Feb 7, 2002 | 08:32 AM
Doodoo's Avatar
Mine is pretty shaky but I have gotten used to it after a year. Tighten bolts down, use loc-tite. I lost my front strut bar bolts and two of my steering rack bolts. That was not fun.
Old Feb 7, 2002 | 08:40 AM
Count Blah's Avatar
Default Re: HCP mounts - driving me crazy (Doodoo)
LMAO i love your sig....i know exactly what that is from....
Ok well its good to hear that this is normal and not something special to my car.
-Todd
Old Feb 7, 2002 | 09:54 AM
SiR Kid's Avatar
New User
Kids I WISH I could find that movie on Kazaa sometime...
Old Feb 8, 2002 | 11:19 PM
JDMCRX's Avatar
Default Re: HCP mounts - driving me crazy (SiR Kid)
hey guys i have the place racing mounts and i beat on my car 24 7 and there still solid and they are realy smoth when the engine idles at 800 rpm the car does not shake at all realy
Old Feb 8, 2002 | 11:41 PM
ImportHatch's Avatar
Default Re: HCP mounts - driving me crazy (JDMCRX)
I lost 1 steering rack bolt and the other one was halfway out. My car would shudder so hard and I couldnt figure out what it was.
Yager-
Lewy. Dee Ayy
Apr 12, 2012 03:07 PM
pubestripe
Oct 3, 2005 09:29 PM
P'nut
Dec 10, 2004 06:38 PM
Aceman64
Sep 16, 2003 12:55 PM
MysteryWagon
Jan 5, 2002 05:19 PM
