crx si intake manifold
Old May 20, 2005 | 08:10 AM
xlusiveracer's Avatar
Default crx si intake manifold
i was wondering if a crx si intake manifold would fit on my honda hatchback std and if it does would it increase my performance.Thanks
Old May 20, 2005 | 08:14 AM
EP3_05's Avatar
Default Re: crx si intake manifold (xlusiveracer)
Yes it will bolt on but you also must convert your wiring to mpfi in order to run the 4 fuel injectors on the d16a6 manifold. The mpfi conversion requires:
d16a6 intake manifold
d16a6 distributor
resistor box
pm6/pm7/pr4/pg7 ecu
helms manual for wiring diagrams
Do a search for mpfi and you should find a more detailed list of parts and also many how to threads.
Old Jun 1, 2005 | 07:57 PM
brad 1.cam's Avatar
does that conversion also apply to a 98 ek hatch??? i was thinking about getting my friends crx si IM and throwing on the d16y7? how much do people usually pay for si manis?
Old Jun 1, 2005 | 08:04 PM
Redline130's Avatar
Default Re: crx si intake manifold (BRAD 1.8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BRAD 1.8 &raquo;</TD></TR><TR><TD CLASS="quote">does that conversion also apply to a 98 ek hatch??? i was thinking about getting my friends crx si IM and throwing on the d16y7? how much do people usually pay for si manis?</TD></TR></TABLE>
In your case, I'd look for a Y8 manifold instead. I wouldn't pay more than $50 for a complete Si manifold (injectors, fuel rail, all the studs, sensors).
Old Jun 1, 2005 | 08:06 PM
FalkenSiR's Avatar
For EKs that came with the weak *** D16Y7 engine, you do the D16Y8 IM upgrade. Very good manifold often called the D-series Type R believe it or not.
Old Jun 1, 2005 | 08:37 PM
brad 1.cam's Avatar
Default Re: crx si intake manifold (fast88std)
and where/how much can i get a y8 manifold.....also one more qestion.....would swapping his SI cam for my cam be a better choice also?
Old Jun 1, 2005 | 08:55 PM
FalkenSiR's Avatar
Try classifieds and yes the Si cam will give you a good hp gain over the B1 cam.
Old Jun 1, 2005 | 09:01 PM
Kryogen's Avatar
I might have a spare Y8 IM for you if this guy doesnt come through By Sat.
OH i got a Si cam too...(88-91 Si cam)
sorwdfish
Feb 19, 2012 09:10 AM
SirSeale
Feb 5, 2009 05:04 PM
rice a roni
Dec 13, 2006 08:09 PM
smash fascism
May 29, 2005 02:25 PM
fausz
Jan 4, 2005 04:22 AM
