Drive axle/hub compatibility?
Can anyone clarify for me which axles fit which hubs? I have a '91 Std. hatch with a zc swap. I have what i thought was an si tranny, but when i went to put the axles in, they didn't fit, they were too small. So i'm assuming that this tranny is a zc tranny, requiring the use of '90-91 integra axles and the intermediate shaft. But at the other end, would the integra axles fit the std hubs? If not, which hubs work with them? Do si axles fit the std hubs? Thanks!
[Modified by carsaregood, 5:50 AM 2/6/2002]
From: A place where stupidity runs rampant aka NorCal
Im not an expert, but i think only std axles with work in std hubs. Im using 90 integra axles with 90 crx si hubs in my standard with a S1 tranny.
-Todd
-Todd
hey
if you want to use the integra axles you will have to get a 5 speed dx or si hubs because the std ones are smaller when i did my swap I have a std to I got the dx spindles cuz the std and hf ones are smaller same goes if you want to use the civic
axles from the dx or si hope this helps
LurkerS8
17
Jun 25, 2005 07:46 AM
