93 a/c problems
I have been told that when I turn on my a/c both fans, Radiator fan and A/C fan should turn, but only the radiator fan turns on. Heater works but not a/c. What could be the problem? Should I change the fan and motor or could it be the a/c pressure switch?
http://www.honda.co.uk/owner/A....html go to a/c troubleshooting there
DO NOT CHANGE ANYTHING UNTIL YOU KNOW EXACTLY WHAT THE PROBLEM IS # 1 CHK THE CONDENSOR FUSE UNDER HOOD FUSE BOX IT MIGHT BE AS SIMPLE AS THAT...if fuse is ok it could be a bad relay,,,diagnose efore you replace and waste money
iNetForce
Mar 3, 2006 03:48 PM
