explain this to me...brake system question
Old May 19, 2005 | 06:31 PM
RTW DC2R's Avatar
Default explain this to me...brake system question
Im not really sure how the entire system works...
If I am bleeding my brakes...fluid reservior is open and full, push down on the pedal, open the bleeder, then close the bleeder before the pedal is totally down...how come the pedal comes back up and doesnt just stay down? what makes it come back up?
Old May 19, 2005 | 06:35 PM
Bbasso's Avatar
Default Re: explain this to me...brake system question (RTW)
A spring silly
RTW DC2R's Avatar
are u joking? lol
Old May 19, 2005 | 06:36 PM
Bbasso's Avatar
Default Re: (RTW)
Well there is sort of a spring thing...( I can't explain) So no joking here.
Old May 19, 2005 | 06:39 PM
RTW DC2R's Avatar
hmmm ok I always thought it was a system that relied entirely on system pressure. can we get performance "spring thingies"
Old May 19, 2005 | 06:40 PM
Dave-ROR's Avatar
when there is fluid there is hydraulic pressure. it'll only stay down with no hydraulic pressure (bad master cyl, bad booster or no fluid).
Bbasso's Avatar
Default Re: (RTW)
Why would you want to make the pedal harder to press? it would kill the feed back when using the brakes.
Old May 19, 2005 | 06:43 PM
RTW DC2R's Avatar
Default Re: explain this to me...brake system question (Dave-ROR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave-ROR &raquo;</TD></TR><TR><TD CLASS="quote">when there is fluid there is hydraulic pressure. it'll only stay down with no hydraulic pressure (bad master cyl, bad booster or no fluid).</TD></TR></TABLE>
even with the reservior open there is still hydraulic pressure? just trying to get a general understanding of brake systems.
Rob, I was joking meathead
Old May 19, 2005 | 06:52 PM
CPR's Avatar
CPR
Good question. Is there no hydraulic pressure when bleeding the clutch fluid? As far as I can remember, when I do the clutch, the pedal stays down.
Old May 19, 2005 | 06:55 PM
Chris F's Avatar
Default Re: explain this to me...brake system question (CPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CPR &raquo;</TD></TR><TR><TD CLASS="quote">Good question. Is there no hydraulic pressure when bleeding the clutch fluid? As far as I can remember, when I do the clutch, the pedal stays down.</TD></TR></TABLE>
Clutch is springy because of the pressure plate springs..
Brake pedal return must be because of a spring in the brake booster. Not sure. Definitely not all hydraulic pressure.
Old May 19, 2005 | 07:06 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW &raquo;</TD></TR><TR><TD CLASS="quote">even with the reservior open there is still hydraulic pressure? just trying to get a general understanding of brake systems.
Rob, I was joking meathead </TD></TR></TABLE>
The reservoir is just a supply when fluid is needed, it isnt under hydraulic pressure
Old May 20, 2005 | 04:44 AM
Chris F's Avatar
Default Re: explain this to me...brake system question (v-attack)
Actually, I think the rotor button screw is what brings the brake pedal back up. I could be wrong, I don't know crap about distributors.
Old May 20, 2005 | 05:54 AM
citrus3000psi's Avatar
Default Re: explain this to me...brake system question (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Actually, I think the rotor button screw is what brings the brake pedal back up. I could be wrong, I don't know crap about distributors.</TD></TR></TABLE>
Im sure thats it.
Old May 20, 2005 | 08:35 AM
RTW DC2R's Avatar
nice
mutiny93
Oct 3, 2011 08:42 AM
Azxster
Oct 27, 2007 08:26 PM
.Thomas
Apr 25, 2007 04:35 PM
92LudeSI
Jul 13, 2005 08:23 AM
robbin
Apr 26, 2004 01:53 PM
