a 92VX ecu no mods...run a 95 gsr motor?
Old Feb 5, 2002 | 07:20 PM
92 CiViC gsR's Avatar
Default a 92VX ecu no mods...run a 95 gsr motor?
my car got stolen, so did my ecu and distributer..i had a 92 vx ecu layin around...i pluged it in..and found a gsr distributer..the car turns over but refuses to start..my exhaust was also stolen..so i just have the headder on...flames comes out of the exhaust...which means iam gettin spark and fuel? any one has anything to say?
help me???
Old Feb 5, 2002 | 07:26 PM
hybridb18c's Avatar
New User
Default Re: a 92VX ecu no mods...run a 95 gsr motor? (92 CiViC gsR)
what year is your motor? what year distributer did you put on? The VX ECU will run the GSR motor(if this is what you have) but it be very rough as far as idle, and will also probably hesitate during acceleration due to the ignition maps. Sorry to hear about your loss. One last thing, are you throwing any codes?
[Modified by hybridb18c, 4:26 AM 2/6/2002]
[Modified by hybridb18c, 4:28 AM 2/6/2002]
Old Feb 5, 2002 | 07:47 PM
to tell you the truth..i didnt check for codes...and the dist is 94-95....other wise the clips wount clip in...the ecu is a 92...and the motor is a 95....but the car is turnin over..but dont want to start...its gettin gas..power..and spark..
Old Feb 5, 2002 | 07:50 PM
ysrhatch's Avatar
New User
save your self the drama and just get a 95 gsr ecu and dist.
Old Feb 5, 2002 | 07:59 PM
boostn5Ghaba's Avatar
Default Re: a 92VX ecu no mods...run a 95 gsr motor? (hatch_react)
I have a vx with a b16(similar to your situation) and I had to use the vx ecu to drive back and forth to work until I got the right ecu and it did ok, good enough to get around, never took it pass 6k rpm. I should start you car though.
Old Feb 5, 2002 | 08:45 PM
TurboBumblBee's Avatar
Default Re: a 92VX ecu no mods...run a 95 gsr motor? (boostn5Ghaba)
sounds like a problem w/ the distributor then if ya ask me..
btrim23
Feb 26, 2005 01:52 PM
B20zvtecek
Mar 12, 2002 05:27 PM
