What can i replace in the bay with 1/4 steel braided line?
Old May 19, 2005 | 02:59 PM
NitroSign's Avatar
Default What can i replace in the bay with 1/4 steel braided line?
im in the process of revamping the engine bay., i want to eliminate as much as possible and i got alot of 4an line. what in the engine bay can i replace with this 4an line. im going to have ls/vtec turbo. thanks
Old May 19, 2005 | 05:58 PM
beepy's Avatar
Default Re: What can i replace in the bay with 1/4 steel braided line? (NitroSign)
You mean with properly assembled hoses or just the hose stuck on stuff?
You can use it for bling vacuum line. Get some of the simulated hose end hose clamps that Proform sells.
Old May 19, 2005 | 10:16 PM
NitroSign's Avatar
this is real steel braided line.
Old May 20, 2005 | 04:05 AM
maxspeedhonda's Avatar
Default Re: (NitroSign)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NitroSign &raquo;</TD></TR><TR><TD CLASS="quote">this is real steel braided line. </TD></TR></TABLE>
He wasn't doubting that it wasn't. What he meant was, are you using real AN fittings or are you going to hoseclap the line on. Then he suggested to get some of the fake AN fitting for bling factor.
Old May 20, 2005 | 05:23 AM
NitroSign's Avatar
real an fitting, no hose clamps
Old May 20, 2005 | 05:20 PM
Wideopentuning's Avatar
Start by taking the factory intake manifold and drilling out all the factory vacuum ports with a 7/16" drill bit. Then tap the holes 1/8 npt. Then you can use npt to -3 or -4 and nipples for vacuum ports. Then you can get away using all nice fittings.
FlewByU352
Jan 5, 2012 06:13 AM
HamiltonRex
Apr 17, 2006 05:17 PM
jthelman
Sep 11, 2002 01:49 AM
ceemarun
Jul 19, 2002 11:57 AM
