Help with manual tensioner
Old May 19, 2005 | 02:07 PM
Ziggymidget5's Avatar
Default Help with manual tensioner
I have an H23 with the manual tensioner (obviously) and I need some help getting my timing belt tight. I followed the steps in the Helm's manual, and this didn't work. It seems tight at some points in the rotation, but others, it seems pretty loose between the two cam gears. My belt is also starting to wear out faster than it should because I think that it is hitting something because it's loose. In the Helm's manual it says to do the tensioning technique with the engine aligned at TDC, but this is where the belt is tight, should I try this NOT at TDC where it is loose to see if that helps or must it be at TDC? Also, how exactly do you perform the "coat hanger" trick, and what has to be removed in order to do this? A detailed walkthrough, or somewhere to find one would really help. And how much would Honda charge to properly tension the belt? I know that's a lot of questions, but any help is appreciated, thanks.
Old May 19, 2005 | 08:56 PM
951dc5's Avatar
Default Re: Help with manual tensioner (Ziggymidget5)
shouldnt it be tight after you adjust the manual tensioner?
Old May 19, 2005 | 10:27 PM
Yea, but it's not.
Old May 20, 2005 | 04:09 AM
m0t0rhead's Avatar
Default Re: (Ziggymidget5)
Are you sure you have the right belt ?
Old May 20, 2005 | 02:26 PM
951dc5's Avatar
Default Re: (Escobar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Escobar &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you have the right belt ?</TD></TR></TABLE>
Old May 22, 2005 | 03:38 PM
Yea, because I didn't change the belt, I just took it off the cam gears and put it back on.
accordmatt
Feb 24, 2011 10:15 AM
94jdmlude
Dec 22, 2008 01:24 PM
graphic
Nov 1, 2004 10:23 PM
GreddySi99
Jul 28, 2003 05:55 AM
dragontegz
May 8, 2003 07:56 AM
