0bd0-0bd1 02 sensor wiring help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingant »</TD></TR><TR><TD CLASS="quote">I need to know exactly what color each wire goes to </TD></TR></TABLE>
1) Do you not know which pins on the ECU do what?
2) Or DO you know what ECU pin does what, but don't know which O2 wire goes where?
For #1 I can get the answer for you.
For #2 you need to get more info. Is the O2 aftermarket or OEM? What colors are the wires? OEM wires I can help you with. Aftermaket you need find out what brand and then maybe somebody can get more info for you. For instance, Bosch has a different color code than OEM. They come with directions for what wire goes where.
