After b-series swap, wont go into 5th and reverse
Old May 19, 2005 | 10:31 AM
Kusai.Nihonjin.Desu's Avatar
Default After b-series swap, wont go into 5th and reverse
Man, one thing after another. Nothing's going right.../rant.
91 CRX SI
XSi swap (b16 + ys1)
Place Racing mounts
Hasport shift linkage
I thought that the place racing shift linkage was not working right (same issue, no fifth/reverse), so I bought the Hasport linkage.
Well, while the hasport looks much better and suited for the purpose, the damn tranny still wont go into fifth and reverse.
All the while, it seems like 1st and 2nd are located where 3rd and 4th should be, when shifting.
Any ideas? Do I have a piece of **** for tranny?
Old May 19, 2005 | 10:45 AM
d357r0y's Avatar
Default Re: After b-series swap, wont go into 5th and reverse (Nihonjin)
if you take the shift linkage off, are you able to put a screwdriver into the bar on the tranny and put it in all gears?
Old May 19, 2005 | 10:56 AM
Brownjd's Avatar
Default Re: After b-series swap, wont go into 5th and reverse (d357r0y)
would it be possible to have the shift linkage mounted wrong
upside down? stabilizer bar crossed? something like that? maybe i'm just a tard
Old May 19, 2005 | 11:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">if you take the shift linkage off, are you able to put a screwdriver into the bar on the tranny and put it in all gears?</TD></TR></TABLE>
hmm, havent tried that yet. definitely will check this out.
I just got off the phone with my buddy up at Honda, he said since 5th and reverse are in near location, these 2 might be screwed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brownjd &raquo;</TD></TR><TR><TD CLASS="quote">would it be possible to have the shift linkage mounted wrong
upside down? stabilizer bar crossed? something like that? maybe i'm just a tard </TD></TR></TABLE>
We thought this too. But it wont fit any other way. Both Place Racing AND Hasport linkages.
Old May 19, 2005 | 11:20 AM
EP3_05's Avatar
I second the suggestion to use a screwdriver and run through all of the gears. This will definitely determine what is going on.
vtec93accord
25
Mar 4, 2008 09:43 AM
Boosted_CRX_507
Dec 5, 2007 04:52 PM
B-B-K
Jul 22, 2004 08:10 PM
VtecDA9
Aug 4, 2003 06:33 AM
