My front is Higher than back
I got my car lowered on January 1st. Now they installed the Eibach pro kit and did an alignment. Now my front looks a bit higher than my back, will this be level when I get Shocks?
believe it or not, this is normal for eibach springs.....the wheelwells are larger on the front than the rear and since eibachs lower the same amount both front and back it makes the front appear higher.....neuspeed and H&R take that into account and lower the front a bit more but some people complain that makes the car look "raked" or pointed down in the front....but to me it looks more even.
Man, I was gonna go with eibach prokits.
Is it really noticeable? If it is, I'm gonna go with H&R.
Btw, if I get coil overs like ground control, will I need to buy aftermarket shocks?
Hey, my friend has that body kit. That's the wings west body kit, right?
How come you didn't get the rear lip(?) with yours?
My friend is also missing the rear one and is desperate to buy one, but he's poor right now.
I had the same problem with my eibachs. It was especially bad when I had my amp and sub in the trunk. I got koni yellows, raised the rear an inch or so using the perch and now the back is higher than the front. But with my stereo in it should be just about even.
i know for a fact its not an equal drop. But it is intentionally done that way for performance reasons, not really looks. the front of mine has a lil more clearance, but i dont think the car is actually higher up front. just looks it.
