FS: Hydro GSR Internal Tranny Parts & Cases
I have for sale an almost complete set of GSR tranny parts... the 1st and 2nd bearing on the counter shaft went bad as you can see in one of the pics of the tranny case... The clutch housing is in excellent condition... I can separate most of the parts so just let me know what you need and make me an offer. All 3 shift forks are in good shape, no bends... I have all of the casing bolts, the reverse change holder, two shift rods, the shift mechanism, reverse switch, bottom half of the VSS, differential, rubber bootie for the shift linkage, 4 of the hollow bolts with the steel ball on the end... whatever you need, make me an offer. I am located in Baltimore, MD. Pickup for this stuff can be arranged. the 3rd gear on the main shaft has 4 teeth missing. Both of the friction dampers on the counter shaft need to be replaced but they are only $13 a piece... The whole counter shaft is complete minus the two bearings at the top. The mainshaft is complete, but the second collar seems to be siezed to the shaft, I broke the teeth of the 3rd gear on nthe mainshaft trying to press the gears off... however, the bearing at the top of the mainshaft is good. Both bearings inside the clutch housing are prefect. So start making some offers on this stuff.
Vouch link in sig...
AIM: BulletProofB16
Paypal: BulletProofB16@comcast.net
I only accept paypal for your protection as well as mine.
Modified by onezexycrx at 9:30 PM 6/1/2005
AIM: BulletProofB16
hey wats everything i'd need to get a tranny running...just tranny parts! ya know like clutch,pressure plate,flywheel, shift fork,throw out bearing,slave cylinder, master cylinder, shift-linkage, axles w/ mid-shaft...anything else im missing?
