bad engine leak - whats causing it?? pic incl.
Old May 19, 2005 | 07:58 AM
SuedeB's Avatar
Default bad engine leak - whats causing it?? pic incl.
ok this is not my engine, i have a b18a. but this is where my leak is coming from
its only when the car is on that it leaks. it leaks pretty fast also. thanks in advance for any help!
Old May 19, 2005 | 01:35 PM
msmotorsports's Avatar
Default Re: bad engine leak - whats causing it?? pic incl. (SuedeB)
Either a cam seal or the valve cover gasket is leaking. I'm pretty sure it a cam seal though.
Old May 19, 2005 | 01:54 PM
sadangryboi's Avatar
blah
try the front main seal and valve cover gasket(could be leaking downward)
Modified by sadangryboi at 6:55 PM 5/19/2005
Old May 19, 2005 | 04:19 PM
sickvtec's Avatar
I had same problem before just change cam seals and u be good
Old May 20, 2005 | 06:46 AM
JimBlake's Avatar
Default Re: (sickvtec)
My first thought was oil pump, but you're showing it leaking too high up. Are you sure about that? Oil pump seam begins close to the bottom of your red-circled area.
Otherwise, I'd agree with the valve cover or camshaft seal.
Novz
Honda Civic (2006 - 2015)
Apr 3, 2014 05:56 AM
76 camaro car
Dec 19, 2011 01:30 PM
Gomdohree
Apr 27, 2008 11:09 AM
Mhollaek9
15
Sep 13, 2007 06:02 PM
04accordV6
Jun 14, 2002 10:27 PM
