OT, What could have happened?
I think you need new muffler bearings.
um geez, it looks like stages of too rich to too lean, hope you figure out the problem, did a compression check? is cylinder #4 just too rich or is that oil residue also? what ecu and injectors are you running? I would do a compression check first, maybe a leak down test if you have to take the head off and go from there, best wishes
